This is one of the 48 projects for our Instructables: Made In Your Mind (IMIYM) exhibition at the Children’s Museum of Houston showing from May 26, 2012 - November 4, 2012. Produced in partnership with Instructables, IMIYM is an exhibit where families work together to build different fun, toy-like projects that help construct knowledge and skills related to science, technology, engineering, and mathematics while instilling a “do-it-yourself” attitude in kids so they feel empowered to explore, tinker, and try to make things themselves. To learn more, check out the article here.
While this project is an original from CMH staff, there are similar projects like the Straw Horn Instructable created by Piroboy94, among others. Often, the materials and process for building our projects are designed for use with a large number of visitors (we see over 800,000 annually) and the need to ensure safety in a mostly non-facilitated environment. So, yes, many of these projects have room for improvement in both materials and methodology, which is PRECISELY what we want to encourage the kids to do. So please do share your ideas for improvement and modifications!
Step 1: What You Need
- 1 – Drinking straw
- 1 – Paper cone cup - like for Sno-Cones
- Scissors
- Masking Tape
- Pencil
Step 2: The Video
Step 3: Step 1 - Making the Reeds
Step 4: Step 2 - Adding an Amplifier
Step 5: To Play
So what's going on? Well, sound is created by vibrations. In the case of the Straw Oboe, as you blow the two flaps hit each other to create vibrations. The straw and the cone on the end amplify the sound, or make it louder. A real oboe works the same way, only it uses two wooden reeds instead of flaps cut out of a straw. An oboe also has keys that adjusts the air flow to create different notes.
This is a great place to begin some experimentation like:
- What if you shorten the straw?
- What if you use different-sized diameters of straws?
- What if you attach a second straw or use two straws of different diameters that slide over each other?
- What if you use different sized cups?
- What if you use cups other than cone cups?
- What if you use cups made of materials other than paper?
- What if you cut holes to try to make notes?
Visit Our Store »
Go Pro Today »
Ðадежда ÐÑÐµÑ Ð¾Ð²Ð° Ð¡Ð°Ð¹Ñ "ÐадежÐнÑе СовеÑÑ"
