3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Strawberry Balsamic Pi Pie
Here's what you need:
6 cups strawberries, hulled and sliced (2 cups reserved)
1 1/4 cups sugar
3 Tbls cornstarch
2 Tbls balsamic vinegar
roll-out pie crust, or homemade pie crust
Here's what you do:
To make the filling, combine all of the ingredients (minus 2 cups reserved strawberries) in a large saucepan. Cook over medium heat 12-14 minutes until it thickens and begins to boil, stirring occasionally. Boil for 2 minutes, stirring constantly. Transfer mixture to a glass bowl and cool completely. (At this point you could use an immersion blender to turn this into jam, if you didn't want to make a pie.) Stir in reserved strawberries. This gives the pie better texture since the cooked strawberries get broken down by all that stirring. Use all of your restraint at this point to not lick the spatula. This filling is like molten lava and will seriously burn you!
Prepare pie plate by lining with one pie crust. Fill crust with slightly cooled filling and bake at 400 degrees for about 45 minutes. If the edges of the crust start to get too dark, cover with aluminum foil or a pie shield.
To make the pi top, cut out pi symbols from the remaining pie dough using a template. I couldn't find a cookie cutter that I liked, so I found a pi symbol that I liked online, printed it out, traced it onto cardboard, and cut out the symbols using and exacto knife. This was a bit time consuming, but totally worth it. Line the pi symbols up on a baking sheet, sprinkle with sugar, and bake 400 degrees for 6 minutes. Once cool enough to handle, arrange the pi symbols in a decorative pattern on top of the baked pie. You could use this same method for any design that you would like. (Think: leaves in the fall, flowers in spring, the possibilities are endless.)
Visit www.dulcisserenus.wordpress.com to see step-by-step photos.
4 comments
Mar 23, 2011. 8:02 PMeddiemama says:
I would like to taste this pie... It looks delicious! ;)
Mar 16, 2011. 11:21 AMscoochmaroo says:
Looks great. I like strawberries and balsamic. Would love to see the full step-by-step here too!
Mar 15, 2011. 3:22 PMRaisedByRobots says:
wow, that sounds interesting. balsamic strawberries. I want to try it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:dulcis serenus
