Introduction: Strawberry Basket to Snowflake
This is a really easy instructable, kids can do it, the materials are inexpensive, it doesn't take a long time, and you can recycle those strawberry baskets saved from this Summer.
Step 1: Step 1
The materials: scissors
strawberry basket
silver glitter
fine wire (thread, floss, is fine as well)
Krylon spray paint (I used 'Make it Pearl'- had it already) you can use white,
silver, or any color you want- (that goes for the glitter too).
I thought glue might be needed somewhere along the line, but I used the wire instead, which is why the tube is blocked out and the wire is stuck on in the photo.
Step 2: Step2
Cut out the bottom of the basket.
Step 3: Step 3
Trim the bottom piece into a snowflaky shape. The small box in the bottom left corner shows how to attach the wire to hang it with. If you do that at this step, (I didn't!) the wire will get painted over and won't show.
Step 4: Step 4
Place the future snowflake on a flat surface, in a well ventilated area. Spray with the paint and quickly sprinkle glitter all over. When this side is dry, flipit over and do the same on the other side.
Step 5: Step 5
When it's all dry, you can hang it on your tree, put on a wreath, hang in a window, or anyplace else you might like to see some 'snow'.
Runner Up in the
Krylon Holiday Decorations Contest
Joby Transform It! Challenge
