Introduction: Strawberry Roses Table Centerpiece and Starter
It's a romantic table decoration and it's a delicious food starter all rolled up in one :-) And what's more it's pretty easy to do!
Step 1: Materials
You need:
A glass
Barbecue sticks
Strawberries
Ribbon of your choice
Floral tape
A sharp knife
Artificial rose flowers with leaves / you could go real here if you wish
some white rocks
Step 2: Making the Stem
Wrap your barbecue sticks with floral tape. Insert the artificial rose leaves and wrap around with floral tape.
Step 3: The Rose
Remove stem from strawberry and prick the point of the barbecue stick gently in to the strawberry.
Cut a Petal at an angle in the bottom level of the strawberry. Do the same in the opposite side.
Now Cut again in between the two cut petals. Do the same in the opposite side so that you get 4 petals.
Move up slightly and cut a petal in between the bottom 2 petals. Do same to the opposite side. Again repeat the process as shown in the lower level of petals till you get 4 petals. Sometimes you might have to stop at 3 petals if the strawberry is small.
Right at top make to small straight parallel cuts. Gently spread the petals open with the knife.
Step 4: Assembly
Arrange your roses in a glass. Fill glass with small white rocks so that the stems will hold it's position.
Wrap a ribbon around the glass and tie a bow.
Take an artificial rose and remove it's petals. Separate each petal by cutting it.
Make a chocolate dip.
Now spread the rose petals on each table. Place the strawberry rose vase in center of the table. Make sure you have enough roses to spare for your guests :-) Place your chocolate dip and step back and admire your romantic table :-)
Isn't that super easy?
Maker Family Contest
Wedding Contest
