3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
String Art Necklace
Step 5Attach the links
Attach the links
Use metal jump rings to attach the links together.  You can make some offset; vary the pattern.
Make sure the string links can lay flat when the jump rings are all vertical.
 If you have enough links, you can simply attach a clasp to your necklace.  If you don't want the string links to go around the back, tie a bit of string or ribbon to each end so you can tie the necklace on, or use wire with the ends bent into a clasp like I did.
3 comments
Jul 31, 2011. 1:55 AMcalinschki says:
Wow! Gonna try this today!
Aug 15, 2010. 9:49 AMdarrenchittick says:
I like what you've done with this. I think it would be stellar if you changed up the shape of the final project so it wasn't just a circle of shapes, but so it had that plus a 'strand' of smaller shapes that hung straight down the back or the front or both or... so many choices! Brilliant work!
Aug 12, 2010. 7:13 PMlauradufresne says:
A Mazing!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
271
Author:supersoftdrink(my etsy store)
I took over my husband's Instructables login last year to make a couple instructables for two contests. He was only using it to browse stuff, anyway. I have a different and sillier name elsewhere on...
more »
