String Tripod
Step 10Tips & Tricks
Shutter Speed:
Using the right shutter speed is essential, you should always use the maximum speed possible.
The rule of thumb for absolute minimum shutter speeds for a hand held camera is 1/focal length. For example a 135mm lens with a 1.5x crop factor (On an SLR) makes it 202.5mm. So hand held you should expect somewhat clear pictures starting at 1/200 or 200 shutter speed. It also matters how far away the subject is, the farther away - the faster the shutter speed needed. The third factor is how far the tip of your lens is from the camera, the further it is - the more it will amplify the vibration.
The string tripod requires a bit of practice and getting used to. I did not notice much of a difference at first, but after a while it really helped. After some practice, it should improve the minimum shutter speed to 1/2 or 1/3 that of hand held. With VR or IS and the string tripod, you should get 1/4 or 1/6 that of hand held.
So, if you are first starting out I would not go any slower than 1/100 with a string tripod at that focal length. As you can see in the chart I made in the instructable, after practice and with VR I can get clear pictures at 1/2 sec shutter speed at 300mm equiv at 10 feet.
With all of this said, it is extremely hard to generalize these numbers and each person is different. There are limitations on this design and those limitations will be different with each person. If you have not determined these limitations for you, leave the camera on P or Auto - this should optimize the shutter speed. Keep experimenting and don't give up, it will be worth it
Technique:
To take steady pictures in general do the following:
-Get a good footing
-Compose your shot
-Keep your elbows tucked in
-Take a breath and hold it in
-Slowly depress the shutter
-Keep the camera at your eye for a few seconds after the picture is taken
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:shoeBlade
