String Tripod
Step 6Using as a monopod
Using as a monopod
To use as a monopod, take your camera and put it just below eye level. Next take the cord dangling from the bottom and loop it under your shoe. Take the remaining cord and hold it tight in your hand while gripping the camera. Now pull up on the cord to camera eye level and take a picture. The cord should be taut. An advantage to this is that it prevents a rotation axis because you are holding the cord in your hand away from the attachment point.
This is my preferred method when I need to move around a lot or need to setup quickly. If you have the hook already attatched to the camera it will take less than a second to get into position.
You can also tie a large loop at the end where your foot would be using a overhand loop and put your foot through it. You would not have to hold the end in this configuration.
NOTE: For each of these methods it is important that you do not put excess force on your camera. As every camera is designed different, you need to determine the amount of force your camera can take. With that said, I have been using this method for years with many different camera with no problems.
1 comment
May 6, 2007. 2:53 PMricardo99 says:
wow..very good!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:shoeBlade
