The materials used are recycled from transformers and motors.
This magnet can lift over 30lbs (14kg)
This instructable is in the Epilog Challenge. Don't forget to pick your favorite.
Remove these ads by
Signing UpStep 1: Parts & Tools
1 Transformer
Enough magnet wire to fill the core.
Tools:
Box Knife
Pliers
Slotted Screwdriver
Small Hammer
![EMP HDD Launcher, [HD Video]](http://www.instructables.com/files/deriv/FUM/QO3R/GQBCI72I/FUMQO3RGQBCI72I.SQUARE.jpg)
Visit Our Store »
Go Pro Today »
thank you
The small electromagnets are hard enough to pull off of something. I would like to seen what a mot would do.
Never the less around 1/2 a kilo of copper magnet wire from an old microwave oven destined for the garbage bin can't be all that bad, and if any one knows of a way to soften the varnish that is used to hold the coils together 'with out damaging the wire's insulation' ........
please don't try this with a MOT
I alredy have and it killed preaty much evrything electronic around it when I hooked it up to my electric fence power supply.(10 000 volts)
It also sucked the ring I was waring to it and I started getting zapped by the current.ouch.
The temperatures should not goes above 80C.
Please tell me the wire turns and diameter in mm.
Thanks
Mazdak
My 12V magnet has about 650 turns of 0.3mm wire (about 66 meters).
A 24V magnet will need a lot of wire. 200 meters of 0.3mm diameter wire has a resistance of about 48 ohms which will draw 0.5A @ 24V. You could use thinner wire, but anything much smaller is very fragile.
24V @ 0.5A = 12 watts which will need a larger core than I used in order to run continuously.
The cores I normally use are 35x25x15mm which run at 10 watts intermittent or 5 watts without heating up quickly. The largest core I have used is 57x38x25mm and it runs at 13 watts and produces very little heat.
Are the magnets going to run continuously? I have never needed to run any of mine for more that 10 or 15 minutes, so I don't know how they will work for extended periods of time.
Thank you ! It seems you have so many experiences for making powerfull electromagnets with low cosumption.
Would you please guide me for making elatromagnets with both sizes: 57x38x25mm and 5x25x15mm
My application is continious(24hr) and power supply is 24Volt.
The power consumption ( W<12 watts) and temperature raise( T< 70C) should be as low as possible.
Can you tell me what is the total turns and size of wire in mmfor each size?
Thank you
Mazdak
The larger core will hold the 200 meters of wire needed for the 48 ohm coil.
I am away from home right now and don't remember the inside measurements of the core, but it should hold approximately 100 turns of 0.3mm wire per layer. I think it would be around 10 meters of wire for the first layer. I can get a better estimate when I get home in a few days.
The actual magnet will differ a little bit because the windings probably won't be perfect and the wire probably won't be exactly 0.3mm diameter.
The core has room for 26 layers with the plastic coil form in place, so it will be mostly full
I will try it
It will need rather thin wire.
The magnet wire is enamelled wire (most of mine came from other transformers).
thanks for the tutorial
Dave
As for electromotive force, it is a large inductor, and will emit a high voltage pulse in the opposite polarity when power is suddenly removed. Use a flyback diode if you are switching it with a solid state device (MOSFET, transistor, etc). You will notice a spark when disconnecting power.
The advantage of using thin wire is that it has higher resistance, therefore less current will flow, and less energy will be wasted as heat
For every two turns of thin wire at 1/2 Amp, you get the same magnetic field as one turn at 1 Amp.
So (up to a point) more turns of thin wire will give much greater efficiency than less turns of thick wire.
Very simply, the magnetic field strength is proportional to the number of wire turns times the number of Amps going through it. (The scientific unit is "Ampere-Turns",.)
It's worth checking the wire resistance per metre, measuring the coil diameter and doing the math in advance, to get the greatest magnetic field strength for the power you are putting in.
And it helps to avoid blowing up your power supply.
The steel core strengthens the electromagnet by improving the magnetic circuit, so the "E" shaped laminations are best, with all three ends touching the item to be lifted.
Have fun !
if you had a copper wire and a copper pole then you would be able to pass the same amount of energy through each and the wire may melt, due to higher resistance, and the pole would be able to take more energy because of the lower resistance.
this high release of heat energy is why a strip heater uses a thin wire.
It's wonderful that you are taking an interest in the depths of the science, but it is rather irrelevant for the purposes of the average instructable.
If anyone really wants to know that the thermal motion of ions is the primary source of scattering of electrons (due to destructive interference of free electron waves on non-correlating potentials of ions), and is thus the prime cause of metal resistance, they look it up on Wikipedia.
But it's not actually very useful here. Please don't be offended, I'm just trying to keep you from aeronautically ascending at figurative hyperbolic tangents. ;-)
Please let me correct your post slightly:
If you pass the same current, say 1 Amp, through a pole say 1 Ohm, and a thin wire say 100 Ohms, the pole dissipates 1 Watt, the wire dissipates 100 Watts. (Power, not energy.) The pole would dissipate less power due to it's lower resistance.
I do, however, disagree with what you said about what we should look up on Wikipedia, for two reasons:
One is that i might not know what to search up, if i had no knowledge at all about it.
Second is that people do not have to read it, but a lot will,because a lot care. I know that i especially love instrutables that explain why something happens. and the more in-depth, the happier i am
Ralph
Anyway, thanks
Btw verry nice instructable. I, myself, am trying to build a magnetic sheet metal with a couple of your electromagnets. Got any tips? I will kee you updated on the project if you would like.
When I made my 12v electromagnet it needed 650 turns of thin wire which was probably around 200 feet.
The electromagnets will get warm, but they shouldn't get hot immediately.
If you get big sparks when you connect the magnet, then it is probably pulling way too much current.
Try using a couple of D cell batteries instead of a 12v.
Multiple magnets can also be wired in series.
The cheap transformers are dipped in varnish to hold them together and that is probably what was chipping away. The enamel insulation is pretty tough stuff.
Thanks for everything
Thinner wire has more resistance so less current will flow, which will make the magnetic field weaker unless you use a higher voltage.
One of my magnets has thick wire and runs at 2 volts and another has thin wire and runs at 12v. They both use about the same wattage and lift about the same amount of weight.
I am still working on determining the voltage.
I would use the standard "by guess and by golly" method.
I'd guess at a voltage and by golly it might work.
If you used 100ft of 22awg wire what voltage would you use?
What about 50 feet of 32awg?
I thought thicker wire higher voltage but you seem to imply thinner wire higher voltage.
I suppose you can make more turns with a smaller gauge wire.
I'd to see something definitive beyond the best guess method, or using experience since I do not have any experience.
It seems most coil projects use experience "this worked in the past" for 12 volts so I'll just do it again.
Thanks again,
Ralph
100ft of 22awg is 1.9 ohms. It should work with 5 or 6 volts. Just watch the temperature. 32awg is rather hard to work with.
I just made a 12v magnet with 0.3mm wire which is between 28 & 29awg. It has 650 turns which is probably around 200ft.
If you are using DC you can use a wire resistance chart & ohms law to estimate the current the coil will use.
When using recovered parts that you don't know the ratings of, there can be some experimentation. It helps to have an adjustable power supply for testing though.
650 turns blows sudharma's 6 turns per volt out of the water.
The "length" of the wire effects the ohms so it doesn't seem it is only the number of turns to determine voltage.
I think I'll just have to experiment to gain the experience. At least now I have something to start with, again thank you for the Instructable.
When running from AC the number of turns is more important than the resistance.
The 650 turn magnet is very strong running from 12v DC, but barely holds its own weight running from 12v AC.
6 turns per volt works well for AC magnets.
Ah, now that's a important little detail.
Thank you
RalphBtw, I find getting the metal plates off the transformer really hard with out damaging it..
Also if you can find a coil winding facility chances are you can purchase cheaply or even get free wire spool ends. An even easier method to get some wire without trying to disassemble a transformer. A task which I personally in light of my experience, would not be my first choice of options. However adventures from trying new things and achieving new victories should never be undervalued.
I haven't come across a well made one yet. The ones I use come from power supplies that I usually get at yard sales and swap meets for free or very cheaply. The larger ones usually find there way into some project or another.
I have also used super capacitors and batteries to run them.
it is very usefull
I used 50ft of 22awg and get 5 amps @ 5 volts.
It could be wound with 100ft of 26awg and get 2.5 amps @ 12 volts.
I just used what I had in my junk bin.
If the voltage is too high for the coil, it will overheat too quickly.
