3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Strong and Tough Platform Bed DIY
DIY platform bed with approximately $60-$90 that definitely will last. Made with plywood, 2x6's, 4x4's, and castors (wheels). More pictures available at www.myplatformbed.com. You will need:
Materials Needed:
3 - 2x6 Boards 10' feet long
1 - 4x4 Post 32" inches to 40" inches long
1- 2x4 Stud
12 - Hex Bolts 3/8 by 6" inches long
12 - Hex 3/8 Nuts
24 - Cut Washers for 3/8 Bolts
1 - 2x4 Stud framing support bracket (pictured)
8 - Screws; 1 1/2" inches
Tools Needed:
Carpenter Square
Tape Measure
Miter Saw (Recommended)
Electric Drill with Phillips Drill Bit
Long 3/8 Drill bit (6" inches or over)
1- 9/16 Socket Wrench
1- 9/16 Wrench
Wood Glue
Step 1Making Legs
Making Legs
We start by cutting the legs of the platform bed. This 4x4 wood I found outside, discarded. Find a scrap one or buy, cut yourself or cut to size at the lumber store.
Cut 8" in length if you want castors on it, 10" if you do not. You may opt for shorter legs (no shorter than 6.5") or longer ones.
39 comments
May 30, 2012. 9:31 PMrjlewis74 says:
This is a sturdy looking design. I'll be making a couple twin beds using this instructable for my two boys. this would be perfect for them. Nice job on this.
Dec 6, 2007. 8:41 PMjimbarbera says:
I recommend perforating the plywood base by drilling several large (~1") holes. Space them 6" apart in a diagonal grid. This will allow the mattress to breathe and prevent moisture buildup.
Sep 19, 2011. 12:21 PMkazots says:
Good thinkin' Batman.
Jun 5, 2011. 9:13 PMNarlo11 says:
I did mine using a stainless steel carriage bolt. I find the hex heads to be unsightly. Then I polished the bolt head. And used red cedar 4X4 as posts and used a red stain and then polyurethane. Also if you can cedar all round.
May 12, 2011. 3:07 PMpadberg87 says:
Awesome instructable! I used this as a basis for my design. I lowered the inside frame so that the mattress sits 1 inch below the top of the 2x6. An old metal bed frame donated its casters to make it easily movable. Seems pretty sturdy.
Mar 13, 2011. 2:17 PMrktompsett says:
Why treated 4x4's? The bed is in the house, not outside, or damp locations. I'd just use standard non-treated lumber. As for slats, go with sheet plywood.
Feb 27, 2008. 6:41 PMteeps says:
Here are the results of my successful attempt! Couple of suggestions: To the author: add plywood to your supply list. To builders: 1 try and find some clamps for securing the legs to the rails when you drill 2 LABEL LABEL LABEL your combos of leg/rail. You will not get perfect drilling on every side so you want to put it together just as you drilled. There is an example of this in my second photo (the sharpie "C"). Woot! New bed!
Mar 4, 2011. 9:37 PMpurpulhaze says:
Did you use plywood or slates? The feet on yours looks longer. Are they? May be a bit late to ask since I had them cut to 10" but I bought 10' so I have plenty left over.
Mar 6, 2011. 7:25 PMteeps says:
Plywood and yes my legs were around 24 inches.
Mar 4, 2011. 9:38 PMpurpulhaze says:
So the mattress doesn't sit inside the frame right? It sits on top?
Mar 3, 2011. 11:21 AMpurpulhaze says:
I like this simple approach. Hats off to you sir! Has anyone came up with a way to add a headboard...?
Dec 4, 2007. 8:34 PMcamp6ell says:
i don't understand the comment in step 6: "You can't afford gaps with a wood strip support system."
Oct 11, 2010. 6:29 PM3DMHuff says:
Three years later... Wood slats can shift and possibly move to where they fall through the gaps. Say you use 1"x4" wood slats and to save money you cut a 2"x2"x8' into 6" strips. After a few tumbles with with the person of your chosing or a pillow fight or two, the 1"x4" could "walk" it's way off the 2"x2" making the other slates take up the additional preasure. Depending on how far apart you had the original supports, they could fail. And if you have my luck, it will happen while you are tumbling.
Feb 2, 2010. 10:00 AMprospector says:
Next time you might want to try using a cedar 4 X 4 instead of the pressure treated one - cedar smells nice and has less icky chemicals in it.
Oct 11, 2010. 6:06 PM3DMHuff says:
And the Cedar will help keep the bugs away to some extent.
Jul 4, 2010. 11:24 AMrapidprototyping says:
we all need new beds
Mar 28, 2010. 7:40 PMrickjgarza says:
Just finished this today and wow.... took me very little time since I had them cut everything for me at Home Depot. The wife is very happy and even the dog tested it out. Thanks for this great instructable!
Dec 15, 2009. 12:42 PMkimwim says:
M son made this bed 2 weeks ago, wonderful instructions! Thanks so much for posting it. We got the http://www.ikea.com/us/en/catalog/products/60160217 to go under the mattress.
Dec 15, 2009. 12:51 PMkimwim says:
ps. We used the only non-treated 4x4 for the legs available, cedar. It's quite nice.
Dec 8, 2007. 7:53 AMSpokehedz says:
(removed by author or community request)
Nov 1, 2009. 8:40 PMkomecake says:
  What fun is that???
Apr 19, 2009. 8:18 AMshannabelle72 says:
Ummm... not all of us have a Big Lots where we live.
Feb 26, 2009. 1:12 PMplzspoilme25 says:
yes ur wood is dangerous filled with chemicals and such....but i dont think i seen anyone complain on the loft beds????? like the idea still to hard for ME to build...and i'm betting a bit heavy to try to move?
Aug 26, 2008. 6:52 AMdredawg says:
Thanks for the great instructable. So great I had to make one for myself, and I must say it turned out pretty awesome. I did a few things slightly different than you did it. First was to put 2- 2x4's crossways instead of 1 length ways. Oh I also used liquid nail adhesive instead of wood glue. Also I made mine 60"x80" (queen size). All said and done it cost me about $90-$100 CAD and roughly 10 hours to complete, including picking up the materials. ( a few to many blunt breaks too i guess :D). Thanks for the inspiration.
Dec 6, 2007. 4:30 PMtatagatha says:
I've made two almost identical beds. The first when I was in HS with very long legs. my bed ended up 4 feet in the air as some sort of half loft.
Looking back it was a little over built. So, most recently I made a more delicate version using white pine 1x6s for the sides. Once glued with the running support rails(1x2) they turn quite strong. I made L shapped legs with 1x2 to give it very light feet. I'm happy with how it turned out. Then I sprung for the lyred slats from Ikea. Check it out.Check it out.
I can see the main advantage
Jul 1, 2008. 3:23 PMshooby says:
Is that the correct name for those slats?
Jul 1, 2008. 9:49 PMtatagatha says:
The slats I used were the Sultan Lillaker from Ikea. I thought I had used the Sultan Liared slats.. and then I that turned into lyred in my head, which I then made up as an adjective. If I were to give it a definition, it would mean a gentle bend in laminated wood (think lyre like the harp).
Jul 2, 2008. 12:38 AMshooby says:
thanks for clearing that up, nice project.
Dec 6, 2007. 9:24 PMgnomedriver says:
Great project. However, the treated timber is a bit of a worry. This may be a repeat comment and Robbtoberfest and others have posted comments on this but ya gotta think of ya health first and foremost. There are some chemicals in that stuff. Designed for outdoor and ground contact where untreated woods would soon rot and come under attack from insect and fungi. At the moment there is a bit in the local news about carpenters and timber workers coming down ill with repertory illnesses. Take care with it and wear a mask when cutting!!
Dec 7, 2007. 7:29 AMthemostbob says:
If it's old enough (<2003), the treated wood was treated with extremely toxic chromated copper arsenate, and sawdust would be quite dangerous to be around and breath. Not sure I would want it under my bed, either, but ymmv. I like the idea, though. I'd probably try to put some protection on the sides for the floor for when I move it through a doorway on its side.
Dec 5, 2007. 1:44 PMMD_Willington says:
Another way to make the support rails in the sides is to use a table saw to notch out the top of the 2x6.. or setup a jig and use a router to remove the material to form a notch, you can also use a router to "bull nose" the squared end cuts. I had a custom futon made when I was 16, we made our own frame for the futon out of 2x6's and 1x4's...
Dec 4, 2007. 5:18 PMrobbtoberfest says:
This is nice, thanks for the idea. I have only one issue, the treated lumber 4x4s; aren't they a health risk?
Dec 5, 2007. 1:39 PMMD_Willington says:
Get a can of cheap sanding sealer and seal them, job done, no worries...!
Dec 4, 2007. 8:32 PMcamp6ell says:
they used to be impregnated with arsenic chloride, but haven't been for several years now... so it's probably ok if your wood is new... then again, maybe they'll decide in a few years the less nasty stuff in it now is just as bad as arsenic... if you're still concerned, and assuming you can't find any untreated lumber, i would seal the treated 4x4s with several coats of paint or varnish or something before building the bed. they're pretty much hidden, so it wouldn't take away from the aesthetics really.
Dec 3, 2007. 12:29 PM!Andrew_Modder! says:
thats pretty gangster!!.. LOL no, i really like it :-D! I love making big things (like bed, shelf, etc.)..
Dec 2, 2007. 7:13 PMahead says:
This a nice project. I could use a new bed.
Dec 2, 2007. 5:57 PMGorillazMiko says:
these beds are really nice, now i know how to make them! (favorited)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:trz
