Stronger Cheaper DIY Sand Drum
445
5
Posted
Introduction: Stronger Cheaper DIY Sand Drum
Sand drum is basically used to grind different materials or you can say to smooth a material.
For this DIY Tech you will require the following
  • Sand paper 100 grit ( to smooth the wheel )
  • Sand paper x grit ( Where x is your choice yes you can make the drum to be of any grit )
  • Scissors
  • pliers
  • A dc fan blade ( Pretty much any pc fan will do )
  • Super glue
  • A dremel or rotatory tool like drill
  • Tissue paper or a cloth to clean
*Grit is like the smoothness of a sand paper larger the number, smoother is the sand paper.
Step 1: How to Make
  1. Break the fan blades with the help of pliers
  2. Put the left wheel like structure in a drill
  3. Using the 100 grit paper smooth the outer cylinder
  4. Cut a piece of sand paper to cover the outer cylinder of the wheel
  5. Glue it on n thats it
Pros
  • Cheap
  • Really easy to make
  • Long lasting ( once the sander paper is finished you can apply a new layer of sand paper on it using glue #newlife )
  • Close to zero vibration ( thats the reason to use PC fan as it is very accurately made and doesn't wobble or vibrate while rotating )
Cons
  • A lil big in diameter so might not get into smaller places.
* You can take out the magnet and the metal ring that is inside that fan blade. I kept it as its of no use to me at the moment and its keeping the wheel strong as well.
#Peace
Spread love
Spread Ideas
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Paper Contest 2018
    Paper Contest 2018
2 Comments
love it grate idea dude :)
