3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Structured Wiring System Design
This instructable shows the structured wiring system that I designed for my home.
This wiring system provides a centralized location for the following services for all of my rooms (master, 3 bdrm, kitchen, living, garage, office).
1) Local area network (LAN),
2) File server and backup,
3) Telephone,
4) Cable HDTV,
5) Power surge,
6) Power conditioning,
7) Signal Amplification,
8) Internet,
9) Battery backup.
I don't have actual construction photos since I didn't take any but i'll show and describe the final solution that I came up with.
Step 1Schematic and Materials List
The schematic for the whole house structured wiring system is shown in this image. I have also attached PDF file which may be a bit clearer.
Parts Listing:
1) Cat-5e (internet, lan)
2) COAX RG-59 or RG-6 (cable tv, antenna)
3) Phone cable (telephone, cable telephone)
4) Romex Electrical wire (electricity)
5) 4-port Wired/Wireless-N Router
6) 16-port Switch
7) Electrical outlets
8) 8-way video splitters
9) 2-way video splitter
10) Cat5 patch panel
11) telephone patch panel (bus bar)
12) cable modem
13) file server - primary
14) file server - backup
15) surge protecter, battery backup (cable, phone, electrical, lan)
16) cable try (metal studs)
17) outlets (ethernet, phone, cable)
18) cable ties.
Schematic.pdf(612x792) 134 KB
105 comments
1-40 of 105next »
Apr 27, 2012. 6:49 PMjimbarbera says:
Very impressive setup!
I'm using blue jacketed Cat 6 for all Ethernet and gray jacketed Cat 5e for all phone wiring.
For the phone I'm using the blue pair for line 1 but which color pair should be the DSL (U-Verse) modem pair? I'm currently using the brown pair from the POTS splitter, but can easily change it to green or orange.
I am connecting only the pair that is leading to the modem so as to avoid any "stub outs" to other locations in the house.
Thanks!
Jim
Jan 17, 2012. 2:24 PMlaxap says:
Wonderfully clean setup. I like how the cables are nicely bundled.
Dec 9, 2011. 9:28 AMrschlitz says:
Hyper awesome guide. I'm not planning to do this but it was a really interesting read.
May 22, 2011. 7:57 PMpratyushpmhptr says:
(removed by author or community request)
Jan 1, 2011. 6:55 AMnasrudiin says:
Thank you so much for the instructions but really like to know I know you already mentioned. Is there any specific shop you can get the tools or just go shopping?
Thank you
Jan 26, 2010. 7:56 PMabadfart says:
 ok so i got it all set up but one of the computer has limited to no connection and my xbox is not registering at all.  i know i wired it right but they aren't working any ideas?
Jan 27, 2010. 4:43 PMabadfart says:
it worked in my test when i had them all in one room and wired together  threw the switch
Sep 23, 2010. 2:05 AMabadfart says:
ok now the computer is working and i need to check the the wire to the xbox
Sep 1, 2010. 10:50 AMElvenChild says:
where do you live?
Sep 22, 2009. 2:24 PMMike8913 says:
total nub q here. . . . where does your cable box come into play?
Jul 20, 2010. 2:13 AMhintss says:
you mean you didn't use mythTV?! that would've been awesomer, geekier, and made use of the ethernet!
Aug 3, 2010. 12:53 PMhintss says:
You keep that many servers and you don't use *nix? I have 2 servers and a net book, and I run ubuntu on all of them. Oh, and I'm 13
Jul 14, 2010. 11:19 AMMark1955 says:
Hi.....Our house is built and a friend was going to help me out for the router and network switches....I have not gotten through to him. Any ideas for a system that woud work well and not too expensive. Thanks for ant imput. Mark
May 12, 2010. 1:48 PMzchampine says:
 Very nice, how much would this cost though?
Oct 17, 2009. 7:27 PMbuddz says:
 Wow great, clean setup. I do have one question though as I am now trying to wire my home in a similar fashion: What did you use for the telephone bus? and just exactly what is that other white box to the right of the phone bus? Just not sure how I can 'route' the signal out to all the rooms if you know what i mean
Apr 4, 2010. 11:45 AMMike44 says:
@buddz, the telephone bus is a product from Leviton for telephone distribution.  This site here has a ton of them for pictures and what not: http://www.smarthomeusa.com/Shop/Structured-Wire/Leviton-Structured/leviton-Phone-Modules/.   I purchased mine from Home Depot though as they seem to have a pretty good selection.
Nov 1, 2009. 11:25 AMDanNixon says:
Is your telephone system just a distribution system?
Nov 2, 2009. 9:06 AMDanNixon says:
I suppose.
An instructable on installing and setting up a PBX would be good as I am looking at this kind of system for my house.
Nov 3, 2009. 9:04 AMDanNixon says:
I have had a quick look at FreePBX once, but it got lost in a list of projects I have and I never got back to it. We have an Avaya PBX at work and compared to the ols LG system it is much easier to uns and manage, but I would probably go for one of the free systems whenI go back to installing a PBX for my home.
Mar 25, 2010. 3:33 PMjaydenthorup says:
I have one concern, the amplifying the cable signal before the split for the modem may put too much signal into your modem. I was an installer for comcast and the signal for the modem needs to be just right. You can check it at 192.168.100.1 i believe. Downstream needs to be around -10db to +10db while upstream needs to be around 32 db to 49 db but check with your cable company to be sure. Otherwise your speed will significantly be reduced, also sometimes the surge suppressor can affect performance. The local cable company should have grounded the cable outside to remove any possibility of surges in the line as well as it is grounded at the pole(overhead) or the pedestal(underground)
Mar 25, 2010. 10:55 PMjaydenthorup says:
aha... the high transmit means it may need to be split down just a little bit more... like a 3-way or a DC-Splitter aka Tap.
that could increase your upload if you are need a little more bandwidth... just a thought.
Feb 26, 2010. 5:31 PMMark1955 says:
Hi THB43, I could use a little advice ....We are having a house built and I want to have it hard wired. Your system looks great, I think that I need or want at least 2 port in a few rooms.1 so I can hook up a tower for  hulu to cut down on cable and one for computer....In the main work room I need one for my  computer and an extra for visitor or what ever...Same in bedroom one for tv and one for laptop. I was told that I should use cat 6 cable and get a 1gig router. Any help or ideas would be greatly appreciated.Thanks Mark
Feb 27, 2010. 4:10 PMMark1955 says:
Thanks for the response....I will be meeting with the builders electrician in 2 weeks. I have other questions just not sure how to ask. I want to have one computer for my business, and another for the house in our work room.... I want to have port to plug in in the living room as well as the other 2 bedrooms(2 in the master). Later on down the road when I finish the basement I want a port in the guest bedroom. As I wrote yesterday still trying to figure out how to get more free tv, so I thought that having a tower  with a good graphics card in the bedrooms and the living room would be a good idea since we are doing all this before the interior walls are going up.Any other ideas that would be helpful would be greatly appreciated. Thanks Mark
Jan 12, 2010. 2:41 AMfireglow35062 says:
 what brand are the servers that you are using?
Jan 12, 2010. 1:40 AMabadfart says:
very nice i have a bit left to do on mine for instance  as i wright this my server is loading its os and i am waiting on a 500 GB hdd to host my media collection
Dec 11, 2009. 1:56 PMGasperiD says:
Wow, just wow, this makes me want to cry im so happy. When i am a home owner i will definitely have to make sure that i have something that matches this amount of beauty or out does it.
Nov 10, 2009. 8:36 AMxd12c says:
Instead of building the cable tray, there are specail purpose trays out there that have a premade & fit cover for vertical & upside down installation. All depends on the amount of money you want to spend. Panduit may have one.
1-40 of 105next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:thb43
