3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Structured Wiring System Design
Step 3Assembly Details
Assembly Details
This picture shows the overall assembly and its parts.
Cut sheet rock window in the wall of a closet, dont' cut all the way through the wall, just back to the sheet rock on the other side of the wall,
The shelf is build in three sections that slides between the exposed wall studs. Build the shelves back into the wall opening that you created.
I used wood wall paneling (masonite) and MDF (1/2" to 3/4") to create these shelves. PVC tubing to route wires into attic.
21 comments
Sep 22, 2009. 2:24 PMMike8913 says:
total nub q here. . . . where does your cable box come into play?
Jul 20, 2010. 2:13 AMhintss says:
you mean you didn't use mythTV?! that would've been awesomer, geekier, and made use of the ethernet!
Aug 3, 2010. 12:53 PMhintss says:
You keep that many servers and you don't use *nix? I have 2 servers and a net book, and I run ubuntu on all of them. Oh, and I'm 13
Oct 17, 2009. 7:27 PMbuddz says:
 Wow great, clean setup. I do have one question though as I am now trying to wire my home in a similar fashion: What did you use for the telephone bus? and just exactly what is that other white box to the right of the phone bus? Just not sure how I can 'route' the signal out to all the rooms if you know what i mean
Apr 4, 2010. 11:45 AMMike44 says:
@buddz, the telephone bus is a product from Leviton for telephone distribution.  This site here has a ton of them for pictures and what not: http://www.smarthomeusa.com/Shop/Structured-Wire/Leviton-Structured/leviton-Phone-Modules/.   I purchased mine from Home Depot though as they seem to have a pretty good selection.
Nov 1, 2009. 11:25 AMDanNixon says:
Is your telephone system just a distribution system?
Nov 2, 2009. 9:06 AMDanNixon says:
I suppose.
An instructable on installing and setting up a PBX would be good as I am looking at this kind of system for my house.
Nov 3, 2009. 9:04 AMDanNixon says:
I have had a quick look at FreePBX once, but it got lost in a list of projects I have and I never got back to it. We have an Avaya PBX at work and compared to the ols LG system it is much easier to uns and manage, but I would probably go for one of the free systems whenI go back to installing a PBX for my home.
Mar 25, 2010. 3:33 PMjaydenthorup says:
I have one concern, the amplifying the cable signal before the split for the modem may put too much signal into your modem. I was an installer for comcast and the signal for the modem needs to be just right. You can check it at 192.168.100.1 i believe. Downstream needs to be around -10db to +10db while upstream needs to be around 32 db to 49 db but check with your cable company to be sure. Otherwise your speed will significantly be reduced, also sometimes the surge suppressor can affect performance. The local cable company should have grounded the cable outside to remove any possibility of surges in the line as well as it is grounded at the pole(overhead) or the pedestal(underground)
Mar 25, 2010. 10:55 PMjaydenthorup says:
aha... the high transmit means it may need to be split down just a little bit more... like a 3-way or a DC-Splitter aka Tap.
that could increase your upload if you are need a little more bandwidth... just a thought.
Mar 16, 2009. 5:35 PMtyler9613 says:
I just have one quick question- What is the purpose of using a patch panel? I get the switches, but have never came to a setup that required a patch panel... Thanks, Tyler
Mar 18, 2009. 10:28 PMtreagh says:
I like the use of patch panels as a clean way to easily see what goes where. Also, if my kids have been bad, I can just disconnect phone and network to their rooms and lock the cabinet. I use cat-5 exclusively for phone, data, and signal with my home automation/integration business. The versatility of cat-5 allows it to be used for many purposes, and home runs allow it to be re-purposed easily on the fly. If you have a phone jack that you aren't using, make it a data port by plugging the other end into the network patch.
Jul 29, 2009. 10:39 PMnkmower says:
I've heard you can use CAT 5 for phone, so then, if you can dispel my lack of knowledge, can a CAT 5 cable be terminated with a phone connector (RJ-11 ?)
Jul 29, 2009. 11:12 PMtreagh says:
You can, but if you terminate with RJ-45, you will be able to insert a regular phone cable connector and it will work... assuming you wire the port properly. I homeran multiple drops of cat5 with RJ45 to each room of my house from a central "media closet". If I want a port to be a phone jack, I just plug it into the phone patch panel. If I want to re-purpose a phone jack to pass and IR signal for a remote control system... I just connect it to the remote control system in the media closet. Every phone/data/signal can be used in a way that it wasn't originally intended if you wire it with forethought.
Dec 25, 2008. 4:05 PMJeebiss says:
I am a fan of twist ties as opposed to zip ties. Less to remove when one wire needs replaced or rerouted. Also they are alot more reusable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:thb43
