3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Structured Wiring System Design
Step 4Installation Details
  • last photo ←
Here are details of the installation.
12 comments
May 22, 2011. 7:57 PMpratyushpmhptr says:
(removed by author or community request)
Jan 12, 2010. 2:41 AMfireglow35062 says:
 what brand are the servers that you are using?
Dec 11, 2009. 1:56 PMGasperiD says:
Wow, just wow, this makes me want to cry im so happy. When i am a home owner i will definitely have to make sure that i have something that matches this amount of beauty or out does it.
Nov 10, 2009. 8:36 AMxd12c says:
Instead of building the cable tray, there are specail purpose trays out there that have a premade & fit cover for vertical & upside down installation. All depends on the amount of money you want to spend. Panduit may have one.
Nov 11, 2009. 5:48 AMxd12c says:
I can definitely agree on cost being a design factor. I was just wanted to point it out because you were concerned with the ties to the tray or something to that effect. The plastic cable trays don't have that issue. Not only that, I didn't even know they existed until I had to order them for work.
Nov 9, 2009. 8:02 PMrichenbals says:
I have to say, of all the awesomeness contained in your build, I was most inspired by the "spare parts tray". I'll be damned if I don't install one of those on every single build I do from here on out. Honestly, that one little step will save me more time than I want to consider.
Kudos on a job well done!
Nov 7, 2009. 9:03 PMpiratemike says:
im also interested in your selection of power cleaning / UPS
PS: AWESOME job. just bought a new house and am looking at doing something VERY similar.
Nov 9, 2009. 7:56 AMmbear says:
"2) I originally setup the IP address to something like 192.168.1.2.  I can change the IP to something else, but the web interface always reports the original address.  APC sent a new unit with the next firmware version and it does the same thing.  They finally said they have no further plans to provide support for this item to fix this issue."
There are two possible ways I can see to deal with that IP address issue:
1. Use an entry in your HOSTS file to point to the correct location.
2. Download an Internet Explorer Virtual PC image to get the XP support you need. It'll time out after a few months, but until it does you're golden.
Nov 7, 2009. 7:49 PMjdf2525 says:
beautiful job!  my equipment closet should look so nice.
Nov 6, 2009. 7:50 AMledzippel says:
 How much dry wall did you cut into?
Aug 1, 2009. 1:29 PMJSmith1103 says:
Can you provide me with the model number of the APC unit you used? Thanks :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:thb43
