Studded Leather Knuckle Ring
2,955
186
5
Posted
Introduction: Studded Leather Knuckle Ring
I've always wanted to stud something. I even bought a ton of studs in the hopes I could find a use for them. Well, you're looking at my first piece of studded jewelry. They're fast and easy to make, so go ahead and make one for every finger!
Materials
leather
studs
leather punch
ribbon
scissors
lighter
screwdriver
pen
metal ruler
X-acto or box cutter
pliers or tweezers
You do NOT need a mallet. I don't know what I was thinking.
Step 1: Sizing
Wrap a piece of ribbon around the base of your finger. Cut it so it overlaps about a 1/4 inch.
Repeat with the middle section of your finger.
Cut a piece of ribbon the distance between the base of your finger and the base of your top knuckle.
Step 2: Transfer Ribbon to Leather
Mark the lengths of your ribbons on the leather and add about a 1/4" thickness on the inside of the ribbon marks.
Cut on the lines using the metal ruler to hold the leather firmly while cutting straight.
Step 3: Burnish and Punch
Burnish the edges of the leather gently with a lighter. Especially with soft leathers, use pliers or tweezers to hold the leather and avoid being burnt. With stiffer leathers, this may not be necessary.
Mark the placement of your studs.
Punch the two holes in the center of the ring first.
Wrap the ends to the corners when punching these holes so they will line up perfectly.
Step 4: Assemble
Wrap the ends to the corners and add studs.
Add studs to the middle two holes.
Use a screwdriver to tighten the studs.
Note: Thicker leathers require longer stud backs. However, if the back is just the tiniest bit too short like it was on my blue ring, you can use sandpaper to make it thin enough to fit.
Step 5: Enjoy!
  • Sew Warm Contest 2018
  • Remote Control Contest 2017
  • Arduino Contest 2017
Questions & Answers
5 Comments
What's it used for?
Very cool. I know I still have some spikes left from my high school days and now I wonder where they are!
Awesome ! This inspires me to make a cool new collar for my dog. Also, I hate to be a baby, but with a ring or something you wear on your hand, check your local laws before wearing in public. It could be interpreted as a deadly weapon (ala brass knuckles). The laws can be pretty broad in some states.
finger spikes and Catcher in the Rye! My type of woman.
