Studer Speaker DIY
Published
Introduction: Studer Speaker DIY
About: AV Installer and Programmer by trade, modifier of cars and scooters for fun, tinkerer of all things electronic and otherwise.
So I am a Recording Engineer and I want to make my mixes tighter, and at the moment I dont have the space to make a set of Auratones, so I am going to build a Studer A810 Monitor Speaker into an enclosure for Referencing when I mix songs.
Parts Needed:
1 x Studer A810 Monitor Speaker with Amp Card
2 x Perfboard
1 x 2.1mm AC Power Jack
2 x 1/4" TRS Jacks
1 x 18v 888mA AC (THIS IS IMPORTANT) Wall Wart
1 x 16 Pin 1mm Pitch Wire-to-Board Connector
1 x 1"x10" - 4' Common Board
Miscellaneous Wire
Nails
Carpet - Optional (I'm going cover mine with some leftover carpeting i have from building my subwoofer box)
Step 1: Circuit Board Soldering
So I have the schematic attached, and the pinout is as follows
+15V on pin 5
-15V on pin 6
CH 1 input audio on pin 16 (Left of TRS Jack 1)
CH 2 input audio on pin 9 (Right of TRS Jack 1)
CH 1 tape audio on pin 14 (Left of TRS Jack 2)
CH 2 tape audio on pin 7 (Right of TRS Jack 2)
pin 1 connected to pin 2
pin 3 connected to pin 4
Once you have this all soldered up, follow this Instructble to build the proper power supply.
https://www.instructables.com/id/Power-Supply/
Step 2: Laying Out the Back Plate
So now, lay out the back plate, where you want the TRS inputs, the power supply port, switch and LED to go. I used a ruler to make everything nice and neat and level.
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    3 Comments
    This is terrific ! Thank you !
    I found your "instructable" while doing some research trying to figure out how to do the exact same thing myself.
    Do you have a picture of the final product?
    Thanks again!
