Studio 54 Earring
511
14
Posted in CraftJewelry
Introduction: Studio 54 Earring
Ingredients:
- 2 brass ovals
- 6 brass discs
- 6 inches of brass chain, cut into 1 inch pieces
- 16 jump rings, 5mm
- 2 gold plated simple ear loops
Tools:
- Permanent marker
- Chain nose pliers
- Eurotool hole punch
- Wire cutters
- Chasing hammer
- Steel bench block
- Rubber bench block
- Blue painters tape
- Pennybright metal cleaner
Step 1: Texture Discs With Hammer
Stack the steel bench block on top of the rubber bench block. This will protect your table and soften the noise from the hammering. Place a brass oval onto the steel bench block and use a section of painters tape to secure. Using the ball end of the chasing hammer lightly hammer the edges of the oval to create a dimpled look. Move the tape to hammer the entire edge of the oval. Remove oval from block and set aside. Repeat this to texture both ovals and all six discs.
Step 2: Punch Holes Into Discs
Using the permanent marker place dots on the brass discs where you want to punch the holes. Carefully punch each one with the Eurotool hole punch. Hammer the hole on each disc to flatten the edges of the hole.
Step 3: Clean Discs
Following the manufacturer's directions clean the brass shapes using the Pennybright metal cleaner. Dry completely. If you wish to seal the metal, apply the Renaissance Wax to the metal following the manufacturer's directions.
Step 4: Attach Discs to Ovals and Ear Wires
Using the chain nose pliers attach the chain and brass discs to the brass ovals. Attach the earwires with the remaining jump rings
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
