Remove these ads by
Signing UpStep 1Thawing
To Freeze: Seal your beef in a water tight container with as little air as possible. Either sealable freezer bags or a plastic container with a tight lid would work well. If you use a container, try to fill it as much as possible so there will be no air. Bags of course should be easy to seal with very little air.
Never use a warm method to thaw meat. Warm/Hot water = BAD. Microwave = BAD. On the counter overnight = Poor.
Option 1: Thaw over night in the refrigerator. This is a slow process but is the best way to thaw... anything that needs to be thawed, not just ground beef.
Option 2: Place a sealed bag/container of meat in a bowl of COLD water and put the bowl in your sink with a slow trickle of COLD water dripping into the bowl so it overflows into your sink. This will thaw a pound of beef in under 15 minutes, and has results about the same as Option 1. I think this works because of convection: currents of water at different temperatures circulating in the bowl thaw the meat without having to risk a change in texture or quality.
13
comments
Add Comment
bFusion
says:
bFusion
says:
Mr. Rig It
says:
LinuxH4x0r
says:
Add Comment
