Remove these ads by
Signing UpStep 1Identify the Problem
I used the crescent wrench to grab on to the edge of the nut, and tightened it onto the edge so that it wouldn't wander off. I set it up so the handle crosses the rotation axis of nut. This will let me torque the crescent wrench with a large open wrench in the next step.
This has the potential to mess up the interior surface of the nut. It didn't and I didn't care because I was just trying to take it apart, but your mileage may vary.
Quick disclaimer: Every shop safety guide ever published includes "Use the right tool for the job," and most accidents are caused by using the wrong tool, so if you can use the right tool you should. While doing this I was very aware of the risks, and tried not to be any dumber than I was already being.
Seriously, an eye for practical innovation is a very useful thing. It is too bad so much of our society has been dumbed down to thinking that if the "right" professional is not the one "changing my light bulb" (add anything here) - then the job can't be done properly.
My son was taught in one of his school classes that you should NEVER try to do anything to your own car except maybe change the oil - otherwise you could mess up the whole thing - always be willing to pay a professional.
Yeah right! Professionals have their places - but a lot of what goes wrong simply can be taken care of with elbow grease and - like this good instructable - some innovative use of logic.
Here is a couple more:
Warning: May void warranty.
You can use a 2nd wrench(not crescent ) bigger than the first, to give you more torque on a bolt/nut. (e.g. 1/2 closed end on a bolt, and closed end of a 9/16 interlocked on the open end of the 1/2) Force x Length = Torque
You can use some metric and SAE socket/wrench sizes interchangeably .
I'm not taking credit for this chart, I found it somewhere else.
5/16 & 8mm
7/16 & 11mm
5/8 & 16mm
3/4 & 19mm
7/8 & 22mm
15/16 & 24mm
1 1/16 & 27mm
1 1/4 & 32mm
When tools are manufactured, they aren't -exactly- perfect. It's a rough chart to come 'close enough' without rounding heads.
