Stylish Chess Board
1,005
11
6
Published
Introduction: Stylish Chess Board
About: Lover of DIY things .
After watch a movie called Shawshank Redemption i decided to bring to life something i had on mind , to learn play chess . As a DIY as i am would be more enjoyable to play the game on the board made by myself. Better than build the board is to share what i have done.
Step 1: Materials List:
  • MDF 18mm size 47,8mm x 47,8mm
  • veneer wood sheets (mine is macassar ebony for white and another is a darker color for black(dont know the name in english) quantity depends on you if decide to do it the same size as mine board)
  • wood glue
  • shellac(i made with this) or varnish 100ml (3,38 fl.oz)
  • black paint (used on handicraft)
Step 2: Tools
  • Dremel 4000 rotary tool
  • Jigsaw
  • Dremel 335 plunge router attachment
  • Dremel bit 650 (1,8" straight router bit 3,2mm)
  • tape measure
  • set square
  • clamps
  • paint roller
Step 3: Let`s Go
  1. As i prefer FIDE official size of the board (A little bit big ) MDF must be cutted 47,8cm x 47,8cm using jigsaw
(TIP:measure twice cut once)
Step 4: Draw Lines
Next step is to mark dots to guide drawing lines, each square has 5,7cmx5,7cm . Do some marks on the border of the MDF with the help of set square and tape measure.Notice that i did some grooves (3mm width 5mm depth between squares so dots must be with this in mind
Draw the lines and check that everything is right .
Step 5: Using Rotary Tool to Produce Grooves Between Squares
Take a lath and the clamps to help guide dremel 4000 with plunge attached to it and bit 650 to make grooves.Speed of rotary must not be to low or to high , let the cut wood smooth by itself, no necessary to use strength.
!! Despite image above using clamp and lath is some steps ahead the idea is the same : guide the tool straight
Step 6: Painting Grooves With Black Paint
At this time is better to use black paint on grooves and sides of the board (I did it after and it is harder no touch veneers)
Step 7: Cutting Veneers
Use stylet(easier way :or a saw attachment for dremel rotary tool) and set square to cut veneers sheets the same size of squares (5,7cmx5,7cm) . Be very careful when cutting some veneers sheets , some kinds of wood are very easy to break .
TIP: Sdudley has a good instructable to help things like this :
Instructable here
Step 8: Glue Veneers Squares
Glue veneer squares intercalated on the MDF board from right lower corner starting with lighter color (chess white ) . Do not glue all at once.Make 2 lines and put something heavy over to take time to dry after some minutes repeat the process.
Step 9: Trim Edges of Veneer Squares to Match
Again take dremel with plunge but this time use less depth,it is just to adjust grooves . Do it carefully , you do not want ruin the project at this time : less speed , again use clamps and lath to guide plunge .
Step 10: Finishing Processes : Varnish or Shellac
Apply shellac or varnish using a brush or a paint roller . Wait to dry .
DONE
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    6 Comments
    A nicely detailed easy to follow instructable. I also liked the finished product. I'd like to try something like this someday. Maybe also make the pieces.
    Yo! this looks awesome, really good job, now all you need are the peices!
    Thanks . I am still thinking which material to produce pieces .
    Thanks . Next step is to build chess set .
