3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stylish Mounted Keyboard Storage from a Cheap Magazine Holder
Step 3Measure again and Drill
1.) Get your pencil, and once again hold the magazine rack up to your surface. Using the pencil, mark a drill hole onto the surface, through the hole you cut in the mesh.
You want to make certain that you are marking the surface that is directly underneath the screw hole you just cut. Make certain to account for you looking at an angle.
2.) Once you are absolutely certain you have marked where you need to on your surface, gather your drill and drill bit. Begin drilling through your surface all the way to the other side of the surface. try to ensure that the drill stays level through this procedure it will help with the next step.
3.) Once you have created the drilled hole in the surface use one of your machine screws to ensure it can go through the hole with little to no effort. If it does not, consider widening the hole or buying new screws washers, and fittings.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:coloquialist
