Introduction: Stylish and Comfortable Replacement Earpads
Picture of Stylish and Comfortable Replacement Earpads
Things aren't as durable these days as one would like and replacement earpads offered by the manufacturer are just unjustifiably expensive compared the cost of the material they're made of. I recalled I had some spare upholstery fabric at home and thought it might look cool on my pretty wrecked earphones.
Time needed: 40 minutes to 2+ hours depending on your skills
Model of headphones used: Sennheiser PX-100-II
Step 1: Tools and Materials
Picture of Tools and Materials
  • Scissors
  • A needle
  • Thread
  • Upholstery fabric
  • Polyester fiberfill
It is important that the textile is durable, but not too hard. Upholstery fabric is good for this kind of project as long as it's not too hard and therefore feels uncomfortable when pressed against the skin of your ear for extended periods of time. The durability of a textile is measured in Martindale units. A larger Martindale number indicates a more durable fabric. The fabric should also be as breathable as possible so the sound quality is not negatively impacted. And last but not the least, do try to pick up a beautiful fabric.
I had lots of polyester fiberfill from a previous project for replacing air filters and thought it could work nicely as padding because it is not very dense and therefore does not mess up the sound quality. As it happens polyester fiberfill is used in upholstery and replacing the earpads is pretty close to that.
I chose to use thickish cotton thread for durability and to avoid twisting of the fabric due to sliding afterwards. See what you've got and make do.
Step 2: Prepare the Paddings
Picture of Prepare the Paddings
The fiberfill paddings should be cut to about the same size as the earphones are wide. I used the old one as a template.
Cut a circle from polyester fiberfill and then split the fiberfill by tearing it carefully and evenly to an appropriate thickness.
Step 3: Cut and Sew
Picture of Cut and Sew
Just cut some squares that are larger than what the textile needs to be in the end. I first cut some circles that were a bit too small and it just made fitting difficult.
Bind the textile loosely in place with the padding inside stretching the fabric evenly over the earphone. Then bind the textile as tight as you dare. This is to form a groove in the fabric so that makes it easier to see where to sew. If there are folds, try to straighten them out as best as you can.
Then cut the excess and sew around along the groove.
Step 4: Fit the Fabric in Place
Picture of Fit the Fabric in Place
With the padding between the fabric and the earphone, fold the inside of the excess fabric under the seam and tighten the thread. Repeat the same with the other pad. Some dexterity is required. Then, after checking that the fabric is even and the thread is tightly around the groove, make 2-3 knots and cut the excess and/of stuff the thread inside the groove with the other end of the needle.
If you want to wash the pads at some point, I suggest you circle the excess thread around the groove a couple of times before making those final knots. That way you can cut the thread and still have enough to knot it again.
Step 5: Enjoy
Picture of Enjoy
Tune into your favorite radio station and enjoy the feeling of fabric against your ears and the fact that the only maintenance your headphones might require in the future is replacing the cable and/or stereo plug at some point.
These headphones actually feel much more comfortable now and to my ear the sound quality sounds unaffected. Great success!
tomatoskins (author)2016-09-21
This is great! I've thought about reviving some old headphones in similar manner before. I can't wait to see what projects you come up with next!
Yeah well, I've been wanting to do this sort of project for years. My advice is to not procrastinate too much. Making things is such a satisfaction.
Randomona (author)2016-11-25
I came across this instructable by chance but this is exactly what I needed :) Thanks!
joen (author)2016-09-21
I don't have a picture but I did something similar with my head phones. I used an old shirt for the fabric and foam padding. I sowed a hem around each fabric circle and threaded a string through the hem so that I could tighten it down over the headphone speaker and foam pad like a drawstring pouch. You are so right. They are much more comfortable than the original pads! Yours look way better than mine. I highly recommend favoriting this instructable so that you will have it handy when you need to fix your headphone pads.
SebastianM114 (author)joen2016-09-23
I thought about threading a string through a sewed hem, but I thought I had very little margin for error so I decided against that. The extra effort could have improved the end result slightly, but I just wanted to finish these quickly.
kierabarbie (author)2016-09-21
Wow this is amazing work
pantalone (author)2016-09-21
These look really great!
About This Instructable
2,015views
57favorites
License:
Bio: Human from planet Earth who lives for challenges
More by SebastianM114:Stylish and Comfortable Replacement Earpads
Add instructable to:
