3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stylish and easy to make bookshelf
Step 4Attaching to the wall
Once everything is painted and varnished, assemble the whole without the topmost shelf against the wall where you want it to stand (you might need help with that). Add wedges in some places if you need them.
Now drill holes for screws in the gaps prepared for the top shelf, mark the places on the wall where the screws will go out and drill holes for the studs. This way the screws won't be visible from the outside and everybody will have the impression that the shelf just isn't attached to anything. If you're afraid that there is not enough wood left in the topmost gap to allow for a hole to be drilled in it, drill just above the gap - this way the hole will be almost invisible behind the shelf when looking from below anyway.
1 comment
Mar 9, 2009. 6:24 AMkspear says:
Too divide the load, you could also do this at lower shelves at an interval. For instance, you could attach screws at the top, 3rd and 5th shelves OR the top 4th and 7th shelves. Adding attachment points will divide the load. You could also attach at shelf points where you intend to have heavy books resting. Using the same process to drill at the shelf point, the system will still look as though its floating on the wall!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:SimonF
I'm a lot of a philosopher, a good deal of a musician, a fair bit of a geek, a bit hippie, and in my free time I like to build stuff. I like to think that I have enough good taste and imagination to c...
more »
