3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
StyloBuzz - Synthesizer
The StyloBuzz is a small super lofi stylus synth that allows you to play one octave of notes, you can also modify the waveform in 5 different ways using the mode control.
It's really just an easy to build instrument that is lots of fun to play and can gives endless chip style sounds when you mess about with all the different modes.
You will need some basic tools, basic components, a circuit board, and the ability to program an 8pin PicAxe.
If you would like to buy a kit of parts including the PCB and programmed PicAxe you can find one here: Rarebeasts
Happy noise making.
Step 1Parts
Parts
1 x 100nF Capacitor (C5)
1x 10nF Capacitor (C6)
1x 10k Pot(PCB mount) (VR2)
1x 100r Resistor (1/4W) (R5)
1x 220r Resistor (1/4W) (R9)
1x 330r Resistor (1/4W) (R11)
1x 560r Resistor (1/4W) (R12)
1x 820r Resistor (1/4W) (R13)
3x 1K Resistor (1/4W) (R8, R10, R14)
1x 2.2K Resistor (1/4W) (R15)
1x 4.7K Resistor (1/4W) (R16)
1x 8.2K Resistor (1/4W) (R17)
6x 10K Resistor (1/4W) (R2, R3, R4 , R6, R7, R18)
2x 22K Resistor (1/4W) (R1, R19)
1x 100K Resistor (1/4W) (R20)
1x 220K Resistor (1/4W) (R21)
1x Regulator 78L05 (5V) (IC3)
1x Ic Holder 8Pin
1x Toggle switch(miniature PCB mount) (S1)
1x Momentary switch (Small tactile) (S2)
1x Picaxe 08M2 (IC2)
1x 3.5mm Socket(stereo switched) (SPKR)
2x LED (Red) (LED1 LED2)
1x Battery connector(9v)
1x Project box with mounting screws(105mm x 70mm x 30mm)
1x Circuit board
1x Wire Multi strand 20cm (Pad1)
1x heat shrink (40mm)
1x 9volt battery
You will also need the ability to program an 8pin PicAxe. Programmer, program cable etc.
34 comments
Jan 4, 2012. 8:54 AMmikolynn says:
Nice instrument!
Anybody know if is around one instructable or know how to do something similar with an arduino?
Thanks!
Jan 2, 2012. 8:16 AMsuicidal.banana says:
Sorry to say this appears to be a mayor ripofff of a instructable of 2009, tic tac tunes: http://www.instructables.com/id/Tic-Tac-Tunes/
Jan 2, 2012. 8:28 AMquietthomas says:
Are you nuts? Do you seriously think so, or are you trollin? One goes beep beep beep to the tune that's programmed into it - the other is a freestyle waveform generator. I can't believe you're making such a useless accusation. Do you find yourself having trouble keeping up with people in regular conversation? Do you often mean to eat an apple, but end up eating a banana by mistake?
Jan 3, 2012. 1:05 AMsuicidal.banana says:
Wow, no need to get your panties all tangled up, if you've learned to read at school you would have spotted the 'appears to be' part, to me, a person that has made neither, they look like the exact same thing, hence my reply.
But yea, sorry, forgot that the world revolves around you.
Jan 3, 2012. 2:07 AMquietthomas says:
My balls are too big for you to tangle your panties around them. Sorry lover. Kiss kiss. ;P
Jan 3, 2012. 4:49 AMsuicidal.banana says:
Once again, learn to read, i clearly said your panties.
But i am just going to stop replying, since this is utterly useless, and i like instructables to much to get booted over some silly flame discussion. cya.
Jan 3, 2012. 5:12 AMquietthomas says:
Exactly man. Exactly. You probably should have just said "Hey yeah, they look the same, but they don't sound the same! You're right!" in the first place. You know, had the balls to do that... without worrying that it means you can't fight, or don't have cred or some other BS. We all make snap judgements. We're all incorrect sometimes. It's nothing.
Jan 3, 2012. 8:18 AMsuicidal.banana says:
Just have to add a final remark since you appear to label yourself as some sort of winner;
I still say the instructable to me appears to be a mayor ripoff, your replys didnt really change that, hence my remark about dropping the discussion.
Besides if anybody is trolling it must be you, i made 1 reasonable reply, your the one to introduce drama, i just wanted to see a reply from the instructable poster, proving me wrong or not, simple.
But yea, reply whatever you want, ill just check back ina while to see if theres a reply from the actual poster.
Jan 3, 2012. 11:19 AMquietthomas says:
I'm not going to bother. Clearly you don't have ears, and the ability to push play on both the videos supplied. Also clearly; you're a very small person (who thinks the internet is about winners and losers). Charlie Sheen supporter maybe? :P
Jan 2, 2012. 9:46 AMshall1028 says:
Someone needs to obey his own pseudonym and keep quiet...Thomas. An accusation can be said to be unfounded but not useless by the way.
While I agree the two projects are different enough to warrant this one's inclusion here I can't help but think that I saw a similar project in Popular Electronics magazine somewhere around 1979.
Jan 2, 2012. 4:38 PMquietthomas says:
Hmmm... so confusing, have opinion! But MUST STAY QUIET!!!!
Jan 2, 2012. 5:08 PMshall1028 says:
There is much rejoicing.
Jan 2, 2012. 6:19 PMquietthomas says:
Can I come to the party if I stay quiet?
Jan 3, 2012. 9:44 AMsholtob says:
you could do something very similer with a 555 timer chip, if you used the schematic in the link but replaced the buttons with the keyboard pcb and the prong
http://www.instructables.com/image/FJPYZX9GTGD4NE0/breadboard.jpg
Jan 2, 2012. 9:56 PMnvnusman says:
Well, adding a vid negated my images below, so I'll try again!
Jan 2, 2012. 9:51 PMnvnusman says:
As Cephus suggests above, this appears to be an homage to and expansion of this simple portable "pocket Electronic Organ" from the UK, the Stylophone. The original is reputed to have been used by David Bowie and others in the Dark Ages of electronic music. rarebeast's circuit adds and enables customization but cuts of half an octive from the original. A new version is available from ThinkGeek.com for 20 bucks while apparently vintage originals can be had from Stylophone.com. I am reluctant to endanger mine by opening it up to show off its guts, but here are pix and a vid (because rarebeast made a musical instrument and didn't play a song?).
Jan 2, 2012. 2:25 PMmpep says:
No circuit diagram or code. Is this nothing more than straight advertising for your own shop????
Jan 2, 2012. 7:58 PMrandofo says:
I see the the circuit diagram as a download on step 1 and the code as a download on Step 4
Jan 2, 2012. 4:47 PMmoebuspcgold says:
(removed by author or community request)
Jan 3, 2012. 7:38 PMblinkyblinky says:
Can you save the circuit diagram as a jpeg or as an image because on Linux, to download EAGLE takes some extreme configuring.
Thanks.
Jan 3, 2012. 8:58 PMblinkyblinky says:
Thank you so much.
Jan 2, 2012. 10:03 PMmpep says:
As pointed out by Randofo, I have now found the files I thought were not there. Good job on this project. :-)
Jan 2, 2012. 6:04 PMpitty says:
This takes me back I remember building a kit very similar to this when I was a kid back in the 80's It look almost exactly the same. It was one of those Dick Smith Electronics kits from Australia. Back when Dick Smiths stores actually sold electronics bits.
Jan 2, 2012. 8:29 AMCephus says:
Rolf Harris would be proud! Build your own Stylophone!
Jan 2, 2012. 8:21 AMquietthomas says:
Don't forget to try this: http://www.youtube.com/watch?v=0YxAHtdejuI
Dec 31, 2011. 2:51 AMblinkyblinky says:
Once again, amazing work. Question, would this work with an 08m? It appears that you are using more variables and it would not fit...
Dec 30, 2011. 4:04 PMyokozuna says:
The sounds in the video sound an awful lot like atari music. :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:rarebeasts(Rarebeasts Etsy Site)
I run a small electronics design lab in Canberra, Australia. I build a range of electronic goods, but I'm mostly focused on hand held electronic musical instruments. I am also a contributor to Make Ma...
more »
