Remove these ads by
Signing UpStep 1: What You Need...
2. Sheet of regular paper
3. 2 business cards
4. A Piece of cardboard larger than the plate
5. Magnet Wire (preferably 30-32 gauge)
6. A neodymium magnet. I got mine from CMS Magnetics
7. Scotch tape
8. Hot glue
Visit Our Store »
Go Pro Today »
Thanks for answering!
We did find that the thinner wire that came in the RadioShack package was better than the middle-sized wire and we could not get the larger wire to work at all.
As Fred the Penguin said, what Mythbusters tested was a hoax posted on the web, saying that you could just attach a penny to a paper plate covered in aluminum foil, then attach one audio lead to the penny and one to the foil and get sound. Since no electromagnet is created by the penny, and there is no permanent magnet to attract or repel, no movement occurs. Since there is no movement, there is no sound. Thus it was a fake.
Look up "penny speaker" and you'll see the difference between that fake speaker and this real speaker.
Cheers, Jb
Thickness ("Gauge") of copper-wire may be important in this case.
Kipkay, could you please post radius, length of coil and gauge of the wire ?
i was looking into making a speaker and I talked to the guy at radio shack (a very smart guy) and he said that I could cook my music supply without a resister or something. He said to use 8 ohms. what is a safe range of ohms so that it does not suck all the power and if I went to hook my laptop up fry the sound card? also, will more coils=more ohms because of the resistance of the thin wire? and if I used thicker wire, could I have more coils with less resistance (ohms) and would more coils give me a more powerful speaker if I give it enough power?
sorry for all the questions, I'm 14 and don't know an incredible amount about electronics and speakers.
thanks, and once again great instructable!
IIRC, more coils = stronger speaker, stronger magnets = stronger speakers as well.
Do keep in mind your resistance, as not enough will burn out your sustem as both the RS guy and acaz93 have stated. But too much resistance will lead to excess heat or lack of function, so there's a balancing act to be performed. As your resistance also effects your vibration strength (relatively) I believe.
It's been awhile since I've done speaker stuff, so some of my info's fairly general, still trying to jog my memory.
Someone correct me pleas, if I'm way off base here.
