Step 3Finish the Voice Coil
TIP: Tape down the first piece so it holds as you wrap.
Try to wrap it tight. Then tape the final result securely with scotch tape. Remove the magnet.
TIP: You can use a multi-meter to check the ohms. You want to get as close to 8 ohms as possible. You must remove the enamel off the ends of the wire to make contact and the easiest way to do that is to burn it off with a lighter.
Add Comment
