Introduction: Styrofoam Chess Game CNC Hot Wire Cutted
Picture of Styrofoam Chess Game CNC Hot Wire Cutted
This beautiful chess set is hot wire cuted in styrofoam by the method of cutting in two views (front + profile). The board is also CNC hot wire cuted in styrofoam with my MiniCut2d machine. My wife had the idea and I made it (team project!).
Step 1: Cut the Pieces
Picture of Cut the Pieces
I cut all the pieces with CNC hot wire machine in 40mm styrofoam (polystyren insulation material).
The DXF file with all the views of the pieces is available here.
You must cut first the side view and then the front view (with a 90° rotation between the two cuts). The second cut must be 0.2mm-0.3mm lower than the first.
Tips: Styrodur has sometimes different heating values depending on the orientation of the material. With my grey styro K-foam 40mm, I have a heater at 63% in one direction and 61% in the other direction. Attention to put a little weight (object, lead) to maintain the material during cutting.
Step 2: Cut the Squares
Picture of Cut the Squares
This dxf file allows to cut 16 identical squares.
But with seriel cutting, we can cut 64 pieces in one cut. We should not ofset the wire before cutting so that all the squares are identical. I cut at the same time two styrodur gray 40mm plates and two yellow styrodur 30mm plates to obtain 64 squares in two different colors.
I then re-cut all the squares at the same height making horizontal manual movement.
Step 3: Paint All
Picture of Paint All
Paint : acrylic wall paint (do not forget the sides of the black squares of the round)
Step 4: Glue the Squares
Picture of Glue the Squares
Glue : Pattex "100%".
I kept the board in 4 parts for easy transport. I probably will stick magnets to hold them together.
Let's play chess!
charimilly (author)2017-07-25
What is the name of this machine? I do party décor and I am interested in a hot wire cnc that is affordable and small.
RedGuff (author)2017-01-01
My scroll saw will love you!
Thanks for my wood projects.
Renaud Iltis (author)RedGuff2017-01-02
;-) Happy 2017 !
seamster (author)2014-11-12
Wow, that CNC foam cutter looks like it would be a ton of fun.
I make cuts like this on my bandsaw, but this looks so much more precise!
Renaud Iltis (author)seamster2014-11-12
Yes, it's very very cool. It gives you one idea per hour (too less time to do all!). I have various RC-airplane made with it (you can see them on www.frenchfoam.com).
seamster (author)Renaud Iltis2014-11-13
Ah, I wondered if you used it for rc planes! That would be my main use if I had a machine like that.
I was really into combat planes and slope gliders a few years ago, but just ran out of time for the hobby. All my planes and gear have been stowed away collecting dust! So sad. :(
About This Instructable
2,248views
37favorites
License:
More by Renaud Iltis:Shadow theaterStyrofoam chess game CNC hot wire cutted
Add instructable to:
