Sub Micro (Spy) Blimp Building With Hacked Servos
66,400
294
58
Posted in TechnologyRemote-control
Introduction: Sub Micro (Spy) Blimp Building With Hacked Servos
About: Send me a message if you're interested in Technology or Science Workshops in Flanders, Brussels or the Southern of the Netherlands. I have over 15 years of experience in developing and giving creative worksh...
This Ible describes the build of indoor RC blimp propulsion around 10g, suitable for use with a common 11” latex balloon. With a 14” or larger balloon it has a payload capacity for a miniature camera for living room (or workshop) aerial filming.
Building tiny RC blimps has become very accessible with the ultra micro RC-gear available today at affordable prices. Plantraco’s awesome Nanoblimp, a RTF featherweight dog fighting champion, illustrates that. It is just new on the market and if I see it right it must be under 6g, allowing for the use of a 9” balloon. It follows the line set with Plantraco’s earlier Microblimp, with its gondola at 10-12g. The Ballooncraft micro blimp on the other hand has been on the market for quite a while, but using a 17” balloon (putting it near 30g without payload), that’s has become a heavyweight in the Microblimp League.
Anyway it is always more fun making one yourself. For me the trigger was the market appearance of the wonderful tiny DelTang DSM2 receivers, with a weight of 0.23g or 0.65g including connectors. And hacking sub micro servos makes the rest of the build quite simple.You only need to be willing to work with the tiny gear, keeping the total weight near or under 10 g (situating it between Plantraco’s Microblimp and Nanoblimp). Check it out in this video:
I have been building indoor RC blimps for about 12 years now, and dismantling servos has often been the main source for reversible motor controllers and small motors, mainly for the for the tail rotors. For this project the complete three axis propulsion is based on hacked servos.
The servo circuits do not give a perfect proportional control. Actually the concept makes use of the imperfect on/off working of these circuits. In a servo, gets power as soon as the potentiometer is not in the desired position corresponding to the transmitter’s stick position (for some more "theory of operation" on servos check here). But the analogue circuits in ordinary servos do not give full power when the deviation is small. The ones in digital servos do, so these are not suitable for this hack.
As people building tiny RC stuff know, at this scale wiring and connectors become important in the weight. But for this Ible I kept things basic,holding on to the connectors and avoiding soldering. In general soldering is not difficult, but at this scale it does need some experience and the right gear. Obviously this means there is some room for further weight loss, and in step 7 I list some tips for more experienced builders.
You can fly your blimp around in at home and if you have two you can go for a "Plantraco style dogfight" attaching a short pin on the front of each balloon.
Or you can go for a payload version and add a miniature camera. With a large enough balloon a wireless camera is possible, but I kept to a miniature recording camera giving a total weight for camera + propulsion of about 20 g (see last step). Here is a video of the camera version:
If you like this Ible, please don’t forget to give it your vote. Many thanks for your attention!
Hack It! Challenge
Runner Up in the
Hack It! Challenge
Step 1: Required RC Gear
Three ultra micro servos at around 2.5g or less: I used the ones branded Blue Arrow. These allow for an easy fit of the propellers (motor shaft of 0.7 mm).
An ultra micro receiver: I used DelTang Rx33. In any case, chose one below 2g and working on a single LiPo cell (commonly referred to as 1s). Actually many receivers do work on 1s, even if not documented as such. Make sure your servos’ and receiver’s connectors are compatible, or you’re in for some soldering after all. Both the DelTang DSM2 receivers and the blue arrow servos come in a number of connector versions. Specialised online shops like Micron Radio Control. Plantraco or Aether Sciences RC can help in this.
Obviously you will need a compatible transmitter. The simplest one with 3 or more channels will suffice.
A 70 to 140 mAh 1s lipo battery (and a suitable charger): The smallest batteries (around 2.5 g for a 70 mAh) are needed to keep the weight under 10g. A larger battery obviously  gives you a longer flight time, but even as flight time is very dependent on flying style, it is easily half an hour with a 125 mAh (weighing 3.5g). A smaller battery will still easily last 15 min or more and it will make a latex balloon last longer (making room for more ballast to compensate for lost helium).
Leads to connect your battery to your receiver (again the specialist RC shop can help in this).
Three small propellers: I used the Plantraco 32 mm “butterfly” propellers. These are some amazing high performance tiny propellers that fit a 0.7mm shaft. The "AES-H34 - Hélice Micro" from Aether Sciences RC looks very suitable too.
A 1mm carbon rod, about 30 cm long
A piece of Depron, about 10 cm by 10 cm, 1mm thick (if not available 3mm thick Depron can be used too).
Some putty as ballast.
Finally, you will need some cellophane tape (sellotape, scotch tape), a pair of small pliers, a couple of small elastic band, superglue and a pair of scissors. A scale, accurate to 0.1g or better, comes in handy. Soldering is optional.
The balloon is described in the next step, the camera and related stuf is described in the last step.
If you already have a transmitter and a charger for the flight battery, the materials needed will cost up to 80 EUR. If you source your servos and propellers cheap you can bring this down significantly. If on top of that you go for a slightly larger version with a 2g receiver, you can you bring it down to under 30 EUR.
A suitable transmitter and charger shouldn’t set you back more than 50 EUR. That is slightly more than the complete Plantraco NanoBlimp, but then we are talking of a DSM2 system, with far more than 4 frequencies available.
Step 2: Determining the Weight and Choosing the Balloon
You can buy your balloon and/or have it filled with helium at any balloon shop or bring a one-way helium canister home.
I first determined the weight of all parts and added an estimate for the fin (that was not cut size at that stage) and for glue and cellotape.
item                                                           weight in g
3 hacked servos                                           3 x 1.7
3 propellers                                                    0.17
receiver                                                          0.68
80 mAh battery                                               2.6
33 cm rod                                                       0.4
battery lead                                                    0.3
depron fin (estimate)                                      0.5
allowance for tape and glue (estimate)         0.25
Total                                                               10
So the concept promised to be suitable for 11” latex balloon (a common party balloon) or any balloon with a lift capacity of at least 10g. Ballast is added to achieve the desired buoyancy and removed again to compensate for the loss of helium over time.
A fresh 11” latex balloon should lift 11g at least (according to manufacturers reference data for 300m above see level), but you will soon notice a loss in lift capacity. In balloon shops latex balloons to be inflated with helium are commonly internally treated with "Hi-Float". This makes them float longer.The one I bought lifted 14 g (about 30m above sea level).  I ended up using a 125mAh battery bringing the weight on 11g and allowing for about 3g of ballast. As expected regular trimming by removing ballast was needed and as after about 10 hours al ballast was removed. But that is not bad for a 1.5 EUR balloon.
A fresh 14” latex balloon however carries more than 20g so there is some room to last a couple of days (again with "Hi-Float"). For the camera version I had a 16” balloon with a lift capacity of over 35 g available.
Foil balloons keep their helium much longer (up to weeks and can be refilled), but have a higher proper weight, making the minimum suitable sizes larger. My favorite foil balloon for a micro blimp is obviously the Zeppelin NT as sold by the Deutschen Zeppelin-Reederei GmbH https://ssl.kundenserver.de/s7875334.shoplite.de/sess/utn;jsessionid=154edbeeba05160/shopdata/index.shopscript and lifting about 21g. A nice alternative, more commonly available is the 40” Letter ”I“. Its lift capacity of 18g is quite tight for a camera version, but it is possible without the camera or with an extra lean build (like powering both camera and propulsion from the flight battery, see last step).
A not on the helium: for these small blimps pure (99% or something like that) is strongly recommended as there is little buoyancy to spare. But where gasses like “Ballonal”, a mixture of helium with nitrogen used to be popular, nowadays almost all balloon shops work with pure helium.
Step 3: Hacking the Servos
To hack each of the three servo’s start by removing stickers and the small band of shrink tubing holding it together. Remove the top part and remove all of the gears, including the pinion (if your propellers do not match the motor shaft, you can alternatively keep on the pinion and drill out the propeller to fit that). Remove the bottom part and carefully pull out the motor and pot. The motor most often comes out easy, the pot is glued in. Most often you can still pull it out by moderately pulling on the wires. I you feel unsure you can alternatively break open what is left of the servo casing, with small pliers.
Protect the circuit board from accidental short circuiting by wrapping a single layer of tape around it.
Test by connecting to the receiver with the propellers left off. Power up and trim each pot till the motor doesn’t move with the transmitter’s corresponding stick at neutral position.
Choose which motor/function you want on what stick. I usually put the up/down on what is normally the “throttle” (because a stick without auto centering is convenient here), the main propulsion on the “elevator” and the left/right on the “ailerons” (on a mode 2 transmitter).
Step 4: Assembly
The receiver gets wrapped in cellotape too, before attaching it too the middle of the 1mm carbon rod with a little more cellotape. I used a rod as long as possible for best manoeuvrability. With the gear used that was about 32 cm.
A battery mount is made with cellotape. Part of strip of cello tape is covered with another layer of cellotape, sticky side to sticky side. This non sticking area should be at least as long as the battery’s circumference. At about ¼ from the front side of the rod, stick one end perpendicular to the rod and fold the sticky end closed. Now make loop in which the battery fits and close it with the other sticky end left. You should be able to slide the battery in and out.
The servo motors are attached with little elastic bands. The front one is directed forward (main propulsion), at the back one is attached transversely (tail rotor). Check the connectors reach the receiver. If you use a transmitter without servo reverse (like the one shown), check the tail rotor is blowing the right way when moving the stick. If not, mount it the other way around. Putting on the propellers helps checking the correct alignment.
The third motor is mounted near the centre of gravity of the assembly, pointing down. Put on the propeller backwards as you want it at its best performance when pushing the blimp up.
Lock the motors in place with superglue. If you choose to cut off the elastic bands afterwards keep the drop of glue really tiny, sticking the elastic bands to the motor or rod as little as possible. After removing the elastic bands add some extra superglue. If that proves hard, don’t bother, as three small rubber bands will account for only about 0.1 g. Obviously, keep any glue away from the shaft.
Step 5: Balloon Attachment and Trimming
The assembly from the previous step is put on the balloon as shown. Two 4 cm pieces of tape should suffice. You might have to carefully shift it backwards or forward to have the blimp hang in the air with the rod more or less horizontally.
Final trimming is done with putty. The amount should be just enough to have the blimp slowly float down when no power is applied. The place you put the putty should help the final trim to have it hang horizontally.
When flying in high halls you should take in account that higher up and in warmer areas a blimp can have tendency to increase its buoyancy. So it is better to trim it a little heavier. The battery will run down a somewhat faster as you will need more power “up”, but it is better to be safe than sorry.
One advantage of using a latex balloon is that it will lose helium noticeably within hours and come down. When using a foil balloon you should take more care in trimming, as coming down can take days. A spare balloon on a string and double sided tape on top can be a real saver by allowing for some “inverted fishing”.
Step 6: Flying and Fitting a Tail Fin
When test flying, a tail fin proved to be very valuable to make flying straight forward reasonably easy. First the up/down propeller al be it tiny, gives some spin to the balloon. Second, the tail rotor is clearly overpowered. A fin keeps the blimp on its straight path and the extra power still allows for short turning when desired.
The tail fin is made out of Depron and attached with some tape. I made it hanging down so it helps protecting the propellers from hitting floors or walls. Also it keeps the blimp some distance from any landing surface. This proved to be important as the middle propeller looses efficiency when pushing close to a surface, making lift-off difficult. So no hovercraft effect there.
Obviously the weight trimming needed to be corrected for the fin.
With a tail fin flying the blimp is not difficult, but full control will take some practice.
Moving forward does need to be compensated with more upwards propulsion. The front propeller speeds up the air under the balloon creating an upside down wing effect.
I usually start by giving up till the blimp keeps about the same height and then give it just a little more and start moving forward, adjusting the speed to keeping  more or less the same height.
Step 7: Tips on Losing Weight (optional)
As with 11” balloons there is not much lift capacity to spare, loosing half a gram or more is worth some trying.
A relatively easy one is losing the potentiometer and circuit board of the middle motor and soldering the motor to the receivers built in ESC (if it has one, as the DelTang have). Obviously you lose the ability to reverse it, so you definitely to trim a little heavy. On the other hand you gain a lot in proportional control, compared to the servo circuit. You can also use it for the forward propulsion, sacrificing the backwards function. I would recommend the latter in larger rooms as in that case coming back down is probably more important than reversing.
If you’re up to some tiny soldering you can replace the potentiometers with two tiny (1/10 Watt) 4,7 kOhm resistors.
You can consider to replace the connectors by soldering directly to the receiver, but to be able to use a 9” balloon as I believe the Plantraco Nanoblimp does, one needs to bring it all below 6g. That will need another approach and another Ible. (If you’re interested, subscribe to me).
Step 8: Adding the Camera
I use a so called “808 car key micro camera”. These miniature camera's come so cheap (under 10 EUR), they are ideal for experimenting. You will beneeding a small Phillips screwdriver to dismantle it. If you go for the extra light version feeding from the flight battery, you will need an extra male and female plug compatible withe the flight battery and soldering equipment.
There is an abundance of information on the numerous variations on the market at Chuck Lohr’s non-commercial information site. Check it out before purchasing one. I have a so called #3 and a #8 and confirm the #3 is better, as recommended on the site.
Do not expect top quality, but something suitable for fun. The motion blur is quite severe, in particular at lower light conditions. But for me, the main disadvantage is their narrow view angle. I have ordered a wide angle Jelly lens to experiment on improving that, but it hasn’t arrived yet. So I will have to report on that later.
I stripped the camera from its disguise as a key fob, so it they weighs only about 10g. I covered it with some tape to avoid short circuiting the printed circuit board, but keeping free the Micro SD-Card slot and the mini USB port. The tape also keeps the actual camera in place, as it is attached to the printed circuit board with a flexible connection.
A folded Depron strip was taped to the camera to have it hang under the front motor.
If you want, you can power the camera on the flight battery, saving about 4g. In that case you will need an extra male and female battery plug to solder an extra connection in between the flight battery and the receiver (see the last 4 pictures). However I recommend not to charge the flight battery through the camera. The original battery seems to have some protecting/regulating circuit attached, while RC batteries count on the RC charger for that.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    58 Comments
    is there any circuit diagram available for the assembly
    A circuit diagram is hardly applicable, as you do not make a new circuit. You hack the servo's OK, but you plug them in as you always do with RC systems. So the electrical circuit remains the same as in any receiver-servo setup.
    Is there any Video tutorial available to explain, that how to assemble all the parts for this nano blimp model ?
    No, Sorry.
    Personally, I consider an Instructable to be more clear and easier to use as tutorial than a video.
    The popular science article is based on my instructable an was made with my collaboration.
    Sadly enough they didn't mention Instructables in the article, even though I asked them to.
    they sell stuff like this but not nearly as cool!
    hi there. what would the total cost of parts be including the gas?
    No. One fill, lastig about a day (8 hours), will be 1 to 2 EUR in a ballon shop. This cost goes down very much depending on the cannister you buy of rent.
    Confirmed, the analog servo provides a better proportional response by a long shot.
    (for some reason the captcha isn't working properly and I cannot reply to your reply)
    I didn't shoot any video as I was running late this morning but I did put a prop on it and put a lot (90%) expo on the channel controlling the servo motor. I did get what seemed to be a proportional response. I am going to setup a little test rig with strips of paper to see how much wind is blowing in either direction at different stick positions. It seems to be more proportional one way than the other. I also plan to pull apart a hxt500 analog servo and see what that gets me. My friend who asked if I could make a "mini blimp that poops coupons" for her show is very excited. I think my step-daughters are going to like it too. I might have to make a bunch of these and have battles.
    Hi there, I am building this sub micro spy blimp and I was slightly confused by what you are saying about digital servos. I have already hacked one digital servo and I am using a computer radio so I can center it with subtrim as getting the pot perfectly centered has been difficult. If I understand you correctly, I will get better proportional control by using analog servos? With the ability to set exponential curves I think I might be able to get a more proportional response from the digital servo but I haven't tried it yet. Have you? Thanks.
    You got it right.
    I once hacked a chinese servo that was supposed to be digital. It actually showed such a clear proportional response, I doubt it really was digital.
    It's certainly worth a try. As you've already hacked one, mount a prop and see what it gives, just holding it. keep me posted.
    Do you know why there is a loss of heilum after the balloon has been filled for a while?
    Because helium is a very small molecule and the balloon material is thin, it diffuses through.
    gr8...!!! but i have a question though it is not related to the blimp but can u tell me how can i simply run my micro servo??? without arduino or something else......just with a batttery or little modification....??????
    Thanks!
    What do you want your servo to do? Just run continuously in one direction? Run it from one direction to another or have it make controlled movements as a servo originally does (but without an RC receiver I suppose)?
    yup...i want to run it continuously from one direction to another ..........and i also want to know that how can i make controlled movements without an RC receiver ??
    thank u
    Ok, you will have to choose: if you hack the servo for continuous running, it will no longer be able to make controlled movements, as the hack means disabling the feedback, which is the basis for the controlled movement. Start learning more on servo's here.
    To make controlled movements without a receiver or Arduino, you will need a so called servo tester. You can buy one ready made, build it from a kit or build it from scratch like this simple one.
    Hacking a micro servo for continuous rotation, is done just the same way as for standard servo's. This is just one of many descriptions available. Many hacks, like the one mentioned above are meant for use with a receiver, an Arduino or a servo tester. If you want to run it without, you need to remove all electronics and connect directly to the motor. Like this. With this option changing the direction of rotation is done by reversing the polarity, for example with a switch wired like this.
    I hope this gets you started.
    Succes!
    Great instructable! I'm slightly confused though, which is probably due to my lack of knowledge about servos, when hacking the servo, do you literally just take out all the gears so that you're left with the motor and potentiometer, and then attach the input to the servo to the throttle output of the receiver, adjusting the potentiometer to get the trim right?
    Thanks
