3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sub Micro (Spy) Blimp Building with Hacked Servos
  • last photo ←
This Ible describes the build of indoor RC blimp propulsion around 10g, suitable for use with a common 11” latex balloon. With a 14” or larger balloon it has a payload capacity for a miniature camera for living room (or workshop) aerial filming.
Building tiny RC blimps has become very accessible with the ultra micro RC-gear available today at affordable prices. Plantraco’s awesome Nanoblimp, a RTF featherweight dog fighting champion, illustrates that. It is just new on the market and if I see it right it must be under 6g, allowing for the use of a 9” balloon. It follows the line set with Plantraco’s earlier Microblimp, with its gondola at 10-12g. The Ballooncraft micro blimp on the other hand has been on the market for quite a while, but using a 17” balloon (putting it near 30g without payload), that’s has become a heavyweight in the Microblimp League.
Anyway it is always more fun making one yourself. For me the trigger was the market appearance of the wonderful tiny DelTang DSM2 receivers, with a weight of 0.23g or 0.65g including connectors. And hacking sub micro servos makes the rest of the build quite simple.You only need to be willing to work with the tiny gear, keeping the total weight near or under 10 g (situating it between Plantraco’s Microblimp and Nanoblimp). Check it out in this video:
I have been building indoor RC blimps for about 12 years now, and dismantling servos has often been the main source for reversible motor controllers and small motors, mainly for the for the tail rotors. For this project the complete three axis propulsion is based on hacked servos.
The servo circuits do not give a perfect proportional control. Actually the concept makes use of the imperfect on/off working of these circuits. In a servo, gets power as soon as the potentiometer is not in the desired position corresponding to the transmitter’s stick position (for some more "theory of operation" on servos check here). But the analogue circuits in ordinary servos do not give full power when the deviation is small. The ones in digital servos do, so these are not suitable for this hack.
As people building tiny RC stuff know, at this scale wiring and connectors become important in the weight. But for this Ible I kept things basic,holding on to the connectors and avoiding soldering. In general soldering is not difficult, but at this scale it does need some experience and the right gear. Obviously this means there is some room for further weight loss, and in step 7 I list some tips for more experienced builders.
You can fly your blimp around in at home and if you have two you can go for a "Plantraco style dogfight" attaching a short pin on the front of each balloon.
Or you can go for a payload version and add a miniature camera. With a large enough balloon a wireless camera is possible, but I kept to a miniature recording camera giving a total weight for camera + propulsion of about 20 g (see last step). Here is a video of the camera version:
If you like this Ible, please don’t forget to give it your vote. Many thanks for your attention!
Step 1Required RC gear
Required RC gear
Three ultra micro servos at around 2.5g or less: I used the ones branded Blue Arrow. These allow for an easy fit of the propellers (motor shaft of 0.7 mm).
An ultra micro receiver: I used DelTang Rx33. In any case, chose one below 2g and working on a single LiPo cell (commonly referred to as 1s). Actually many receivers do work on 1s, even if not documented as such. Make sure your servos’ and receiver’s connectors are compatible, or you’re in for some soldering after all. Both the DelTang DSM2 receivers and the blue arrow servos come in a number of connector versions. Specialised online shops like Micron Radio Control. Plantraco or Aether Sciences RC can help in this.
Obviously you will need a compatible transmitter. The simplest one with 3 or more channels will suffice.
A 70 to 140 mAh 1s lipo battery (and a suitable charger): The smallest batteries (around 2.5 g for a 70 mAh) are needed to keep the weight under 10g. A larger battery obviously  gives you a longer flight time, but even as flight time is very dependent on flying style, it is easily half an hour with a 125 mAh (weighing 3.5g). A smaller battery will still easily last 15 min or more and it will make a latex balloon last longer (making room for more ballast to compensate for lost helium).
Leads to connect your battery to your receiver (again the specialist RC shop can help in this).
Three small propellers: I used the Plantraco 32 mm “butterfly” propellers. These are some amazing high performance tiny propellers that fit a 0.7mm shaft. The "AES-H34 - Hélice Micro" from Aether Sciences RC looks very suitable too.
A 1mm carbon rod, about 30 cm long
A piece of Depron, about 10 cm by 10 cm, 1mm thick (if not available 3mm thick Depron can be used too).
Some putty as ballast.
Finally, you will need some cellophane tape (sellotape, scotch tape), a pair of small pliers, a couple of small elastic band, superglue and a pair of scissors. A scale, accurate to 0.1g or better, comes in handy. Soldering is optional.
The balloon is described in the next step, the camera and related stuf is described in the last step.
If you already have a transmitter and a charger for the flight battery, the materials needed will cost up to 80 EUR. If you source your servos and propellers cheap you can bring this down significantly. If on top of that you go for a slightly larger version with a 2g receiver, you can you bring it down to under 30 EUR.
A suitable transmitter and charger shouldn’t set you back more than 50 EUR. That is slightly more than the complete Plantraco NanoBlimp, but then we are talking of a DSM2 system, with far more than 4 frequencies available.
43 comments
1-40 of 43next »
May 11, 2012. 9:08 AMShivam Dehinwal Indian says:
gr8...!!! but i have a question though it is not related to the blimp but can u tell me how can i simply run my micro servo??? without arduino or something else......just with a batttery or little modification....??????
May 11, 2012. 11:09 PMShivam Dehinwal Indian says:
yup...i want to run it continuously from one direction to another ..........and i also want to know that how can i make controlled movements without an RC receiver ??
thank u
Jan 14, 2012. 9:25 AMTheGreatO says:
Great instructable! I'm slightly confused though, which is probably due to my lack of knowledge about servos, when hacking the servo, do you literally just take out all the gears so that you're left with the motor and potentiometer, and then attach the input to the servo to the throttle output of the receiver, adjusting the potentiometer to get the trim right?
Thanks
Jan 15, 2012. 12:06 PMTheGreatO says:
Ah! thus eliminating the need for ESC, that is simply genius :)
Jan 15, 2012. 3:12 AMlukeD says:
is there a way to use NO helium?
Dec 15, 2011. 7:09 PMrocketman217 says:
another way to lose some of the weight is to replace all the wires with enamel coated speaker wire, like the stuff they use in headphones .
really liked this instructable! keep up the great work.
Dec 21, 2011. 9:28 AMsolomonhorses says:
Awesome work! thanks for the great pics!
Dec 5, 2011. 6:42 PMHeliosphan says:
Hi
Im intrigued about the filming aspect of it, so I went looking for a vid on YT of that camera - http://www.youtube.com/watch?v=HEupsuwdFQo
This quality isn't half bad, and only has poor panning performance due to not being able to encode the rapid image changes, or no able to write to the memory card quick enough.
Are you seeing this quality, because I wouldn't be at all disappointed to see that quality in something costing a tenner!
Dec 8, 2011. 7:55 AMHeliosphan says:
One other thing, my footage also appears to have better FPS than your footage even in lower lighting conditions. So I'd rule that out as a factor.
Dec 8, 2011. 7:54 AMHeliosphan says:
Hi
I actually bought one of the 808 cameras since your recommendation, thinking for the future as I want to build an RC blimp too.
I have to say, the footage from my camera is about as good as some of the YT vids make out.
Looking at the footage from your camera, I'd have to say your footage doesn't look as good as mine. The image quality is about the same, but yours appears to be recording at a much lower Frames Per Second rate.
It could be the camera itself, or it could be a very slow memory card.
I bought mine off Ebay for £11, and I chose an auction that came also with a 4GB card bundled!
Dare I suggest it, but you might want to look at buying another of the 808 cams, or at least changing over the uSD card.
The footage is definitely lacking in the fine detail areas of the footage, but I really couldn't be much happier with it for the price.
I'm also thinking of getting hold of the slightly costlier genuine 720p models, which look really impressive for the price.
Is there any news on your wide angle lens yet? The angle on mine is quite limiting I have to say.
Dec 11, 2011. 6:57 PMHeliosphan says:
Thats great though,
Whatever increase in viewing angle you can get, the better.
Can you let us know where you got this 'jelly lens' from?
I was thinking actually what if you put a small bulbous drop of water on the basic lens? I will get round to trying that myself probably tomorrow. Of course its not a very permanent or resilient solution, its worth a try and the surface tension might last for one whole flight.
For your info, the ebay seller bundled in the uSD card, its a non-branded ebay job, marked at class 4. But is clearly sufficient.
Whilst more expensive, its always worth going for a well branded card such as a sandisk. If the price gets a bit silly, perhaps its worth upgrading to a true 720p 808 keyfob camera! :-)
Dec 12, 2011. 9:07 AMHeliosphan says:
*Follow up*
Hi
I just tried the drop of water approach, no real joy.
I used a very sharp implement and let a tap drip onto the end until a drop was suspended, then guided it into the lens opening. Tried this three times.
The first and second attempts resulted in totally blurred video, I had managed to smear the water all around the lens casing.
The third attempt resulted in a perfect dome of water protruding from the lens casing, It gave the video a well focused image, but it wasn't at all 'fisheyed' or wider at all, and it had the side effect of weird lighting anomalies entering the lens. I think part of the problem is that the lens is slightly recessed into the lens casing, making it difficult to get water right onto all the glass.
I also accidentally let a load of water into the keyfob casing, some of it got onto the circuit board, I dried it off, and its still working fine.
By the way, a simple dab with a piece of kitchen roll cleared the water from the lens completely, the quality has returned to normal, dare I say it, a little better!
Oh well, perhaps you might get better luck, its all down to getting the water to completely cover the lens glass, and make an almost perfectly round dome of water protrude, I got the dome, but it clearly didn't get to all the glass.
Dec 12, 2011. 8:30 AMHeliosphan says:
Thanks for the lens info. I'll look them up!
Yeah there could be an issue with the vibration.
But ultimately we're talking about only micro-litres of water, so it would be nearly impossible to short circuit any part of a modern production PCB.
The boards are designed with multiple layers of material, one of which is that green protection layer. Sure enough there are bare metal solder areas, but drops of water would have to miraculously bridge a connection between two of these spots to *potentially* cause an issue - but remember also that electricity always takes the easiest path, and an intact PCB offers the electrons a far better path to follow than through water with a relatively higher resistance.
Still I admit all this is theory only! ;-)
If you're concerned about it, I would imagine a small amount of clingfilm sandwich wrap, surrounding the camera PCB, would suffice.
Today I've bought myself some small props, and some 175mAH LIPO batteries from a nearby helicopter shop! My blimp build is nearly in progress! ;-)
Dec 10, 2011. 2:58 PMmeenzal says:
Pretty cute. I made one of these with the working gear from a Vapor micro RC plane after too many crashes. Pretty much just strapping the wingless airplane stick frame upside down to a balloon. Yours is more maneuverable though, and with on board video besides! Kudos!
Dec 11, 2011. 4:13 AMmeenzal says:
Yeah, good idea. I was also giving thought to using a lightweight Sharp IR range sensor with an Arduino pro mini and making it autonomous. I would probably need a bigger envelope than the single party balloons I use. As it is I'm inflating the balloons almost to breaking in order to get neutral bouyancy. :-(
Yours is definitely the best method. Very, very clever!
Dec 8, 2011. 8:42 AMsitearm says:
@masynmachien;Sweet! I love the Blimp camera view. Not only do the blimps work, you are expert at controlling them.
Cheers!
Site
Dec 5, 2011. 6:07 PMHeliosphan says:
This looks good fun, I might have a go myself!
BTW its sellotape, not cellotape, that must be tape for repairing a certain musical instrument! ;-)
Dec 8, 2011. 6:58 AMT ika says:
such a nerdy thing
hihihihihi lol :)
Dec 8, 2011. 4:32 AMmpetitdemange says:
Now that's a cool design. Very smart. Thanks
Dec 6, 2011. 4:53 PMcrazymaniacs says:
awesome project, congratulations on your great work. Do you have any ideas how you would get one of these to fly around on its own, without need for RC? Perhaps if it hits a wall it goes in reverse, etc. You would need some simple control. thoughts?
Dec 6, 2011. 11:56 AMrandofo says:
Okay. That video is great. I wanna try to make one of these.
Dec 6, 2011. 11:18 AMHonus says:
Awesome- love it!
Dec 6, 2011. 11:12 AMvderycke says:
Goe bezig! You got my vote!!
Veerle xx
Dec 6, 2011. 5:10 AMfreeetu says:
?@8:>;L=> ))
Dec 5, 2011. 8:23 PMprank says:
Brilliant!
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
142
Author:masynmachien(land, sea, air and space)
My main hobby is developing creative workshops for children. Since several years now I have been organising those, mainly voluntary at the school my daughter is attending. My workshops most often invo...
more »
