3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sub Micro (Spy) Blimp Building with Hacked Servos
Step 3Hacking the servos
Hacking the servos
  • last photo ←
To hack each of the three servo’s start by removing stickers and the small band of shrink tubing holding it together. Remove the top part and remove all of the gears, including the pinion (if your propellers do not match the motor shaft, you can alternatively keep on the pinion and drill out the propeller to fit that). Remove the bottom part and carefully pull out the motor and pot. The motor most often comes out easy, the pot is glued in. Most often you can still pull it out by moderately pulling on the wires. I you feel unsure you can alternatively break open what is left of the servo casing, with small pliers.
Protect the circuit board from accidental short circuiting by wrapping a single layer of tape around it.
Test by connecting to the receiver with the propellers left off. Power up and trim each pot till the motor doesn’t move with the transmitter’s corresponding stick at neutral position.
Choose which motor/function you want on what stick. I usually put the up/down on what is normally the “throttle” (because a stick without auto centering is convenient here), the main propulsion on the “elevator” and the left/right on the “ailerons” (on a mode 2 transmitter).
3 comments
Jan 14, 2012. 9:25 AMTheGreatO says:
Great instructable! I'm slightly confused though, which is probably due to my lack of knowledge about servos, when hacking the servo, do you literally just take out all the gears so that you're left with the motor and potentiometer, and then attach the input to the servo to the throttle output of the receiver, adjusting the potentiometer to get the trim right?
Thanks
Jan 15, 2012. 12:06 PMTheGreatO says:
Ah! thus eliminating the need for ESC, that is simply genius :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
142
Author:masynmachien(land, sea, air and space)
My main hobby is developing creative workshops for children. Since several years now I have been organising those, mainly voluntary at the school my daughter is attending. My workshops most often invo...
more »
