Subwoofer Hidden in Plain Sight
Introduction: Subwoofer Hidden in Plain Sight
Amps and Speakers Contest 2016
Runner Up in the
I wanted a 22hz subwoofer for my livingroom. After meeting with the budget/aesthetics committee, my wife agreed I could build a subwoofer that would serve as an end table and look like a trunk.
Step 1: Disclaimer
I am by no means a professional and I based my entire process on reading other instrucables and spending time on forums. I learned a lot through the process and would change a few things if and when I do it again.
Step 2: Hardware
Steps 1 and 2 go hand in hand. You need to decide what kind of performance you want combined with how much space you're willing to utilize. I decided to start with performance first and size second so I chose my hardware before settling on a design.
Step 3: Design
Come up with a plan for your subwoofer before purchasing building materials. I used a free program called winISD to help calculate my design based on the driver and performance I wanted.
Step 4: Materials
Using your design calculate how much material you need. I build mine out of 3/4 MDF, everyone online recommended 1/2 or 3/4, I chose 3/4 to play it safe.
Step 5: Cut and Assembly
If you're confident with your measurements you can cut all your pieces then assemble or you can cut and assemble as you go.
Step 6: Break-in
After assembling the enclosure I decided to install the driver and amp and let it run overnight using sweep tones to break-in the driver.
Step 7: Paint
I decided to paint all the areas that wouldn't be covered in leather.
Step 8: Wrapped in Leather
Began wrapping in leather. Attached leather with contact cement.
Step 9: Accents
Added hardware accents to make it look like a trunk.
Step 10: Finish and Enjoy
After the paint was dried I finished assembling everything, and began shaking the house.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    Wow, You are all set to open 2 business Trunk making and Sub woofer design and manufacturing. The design is awesome, Any plan's on selling some be sure to post a link.
    Thank you very much. No, I don't have intentions of selling them. ?
    Could you talk about the amp / crossover and the electronics you used please.
    The amp is a Bash 300s. I actually just use my receiver subwoofer output as a crossover. I know it's not the best crossover but for my use it works great. I run the amp full range and set my receiver subwoofer output to 80hz
