Step 3: Preparing To Plant
Fill the tube with more drainage material.
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
You will find that by adding drainage material that you are effectively reducing the size (volume) of your container, and effectively raising the water level that the soil holds. The equilibrium between capillary action (up) and gravitational flow (down) in the soil remains the same, just now in an effectively smaller container.
Just a tip. You don't need a hole/tube in the middle of a pot if your soil characteristics promote drainage.
