Successful Motorized Foam Plane
Introduction: Successful Motorized Foam Plane
I'm so passionate about making things. Especially things that fly. Today, I've tried to make a small plane from foam plate and a plastic tie rap stick.
Actually, I started it as a small foam plane that could be easily assembled from simple stuff.
After I test it for flight I thought : Why don't we make it electrically powered?
And so I attached a motor and a battery to it.
It didn't take longer than fifteen minutes to design and assemble.
I hope you like it.
Thank you for reading my instructable.
Step 1: Components and Tools
I used some simple stuff you can easily find at home.
Plate of Foam
Plastic Tie Rap
Glue Gun Amazon US , Amazon CA , Amazon UK , Amazon DE , Amazon FR , Amazon ES , Amazon IT , Banggood
Step 2: Cut and Glue
Cut the foam plate to get a slice. This makes the wings of the plane.
Cut a small pieces of foam to make stabilizers and rudder.
Use the glue gun to glue the rudder to the stabilizer and to attach them to the tie rap.
Attach the wings to the tie rap.
Now you have the plane structure ready to go.
Step 3: Balance and Test
Of course when I tested this plane it was unbalanced. So I attached a small piece of play doh to balance it.
Tested working great.
I thought: Now we can make it motorized.
Step 4: Motorize and Test
I used a small 7mm DC motor with a propeller powered with a 3.7V Li-Poly Battery
7mm Coreless DC Motor with propeller
3.7 Volt Li-Po (Lithium Polymer) Battery
I connected the two terminals of the motor in a way that makes air flow backwards of the motor.
This way, the motor Pulls the plane.
Make sure to determine the direction for thrust of your motor.
I used tape to fix the motor at the tip of the stick and the battery on the wing.
It worked fine. Wait for the flight video.
That's all. Thank you for reading.
Here are some of my latest books on Amazon.
Learn By Making
Backyard Wind Turbines
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    hi sir, where is the flight video ?
    the dimensions of this plane please ? thanks
    The wing span is exactly the length of the foam plate. In my case, the foam plate length was 30 cm.
