Succulents in cans for an indoor plate garden
Step 1: Supplies needed
Supplies needed:
-succulents of your choosing (i got mine at lowes)
-plate (this is actually a stainless steel dog food "platter" that was on clearance, but any plate should be fine)
-cactus soil
-cans of various heights
-pebbles
-dremel or other drilling tool
Step 2: Drill holes
Drill drainage holes in bottom of each can
Step 3: Filling the cans
Fill bottoms of cans with pebbles for weight and drainage
Fill cans about half full with cactus soil
Step 4: Plant the succulents
Remove plastic pots and insert plant into can
Fill in around the plant and adjust height of soil if necessary
(succulents can be planted close together since they are slow growing)
Step 5: Finishing up
Fill plate with pebbles
Arrange cans on pebbles.
Done!
Make sure to follow the label directions for the succulents and don't over water them!
Iamadragon says: May 10, 2013. 7:48 AM
Awesome! I'm definitely going to do this.
3681096 says: Apr 24, 2012. 7:51 AM
you explain really easy and nice ofcours im from iran but i like your site
joen says: Apr 10, 2012. 9:49 PM
I wonder if this would qualify for the metal challenge. Otherwise it is too bad there isn't a "What to do with a used tin can" contest. This would make a good entry.
kriste3582 (author) says: Apr 11, 2012. 4:59 AM
Thanks for the input, i entered it.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
