Step 13: Thoroughly water the panel
After each panel is installed, thoroughly soak the panel with the hose. This is very important because if the panel is dry, the felt will not wick the water and the drip irrigation will not be effective. The drips will simply run out the bottom of the panel.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
