Step 15Instruct quilters
Next, show them how to take cuttings and insert them into the quilt.
Each cutting will be stuck into a slot that is cut through the black fabric and top felt layer. Use scissors or a knife (assist children) to cut through these layers until you can see the brown coco mat layer. Insert each cutting by slipping it through the slot with the stem or roots pointing down. Use the location of the drip emitters to help people know which end is up.
To take a cutting, simply use sharp scissors and cut off a stem from a plant. If the plant is more of the ball shaped variety (i.e. hens and chicks), separate out a baby. If the plant is in a pot, empty the plant onto the table and pull apart all the separate balls. Shake off some of the soil from the roots and stick the roots into the slit.
It is even better if the cuttings can sit for a day so their ends can dry out. This is especially important if you want to put in any cactus cuttings. I don't do this with quilters because the spines can be a pain. (Hint: To root a piece of cactus, cut it off with a sharp blade, spray it with isopopyl alcohol, and let it sit indoors in the shade for a week. Then shove it into a slit in the fabric and wedge it in well. Use gloves! If it rots, remove it, cut off the bad end and repeat the process. Maybe let it sit a little longer.)
Add Comment
