Suction Cup Fishing Rod Holder
3,771
28
Published
Introduction: Suction Cup Fishing Rod Holder
So I have recently gotten into paddle boarding and instead of just getting exercise, figured I'd do a little fishing too. I did not want to drill the top of my paddle board and also wanted something removable. Thus, the suction cup rod holder.
Step 1: Parts List and Tools
Parts
-Rod holder, I already had one from my boat, but they run around $17 from Cabela's. If you are really crafty, you can probably build one from PVC
-Dual Suction Cup, the kind for moving glass $8 from Harbor Freight
-U-Bolts size varies by suction cup and rod holder, mine are 1.5"
-old bike tube
Tools
-socket wrench
-hacksaw
-scissors
Step 2: Construction
The first step in construction is mounting your rod holder base to the grip portion of the suction cup. Mine had a slight groove on the bottom that made it fit better on the round suction cup grip.
I cut a 3" by 3/4" piece out of an old bike tube to prevent the base from sliding around on the suction cup grip. This may not be necessary, but I thought it might help out.
Next I roughly mocked the u-bolts into the holder base to see how much I needed to cut off with the hacksaw. While cutting, I find it easier to screw the nuts beyond where I am cutting so they can re-thread the cut end when they come off after cutting.
Last step is to put it all back together, with the bike tube between the rod holder base and the grip of the suction cup. The u-bolts will "v" a little as they tighten, but be careful not to over do it.
Step 3: Gone Fishing
I was a little unsure of the holding power of the suction cups at first, especially with a couple of hundred bucks in gear being held on by it, so I opted for a safety rope on the first trip. I used 1/8" p-cord as a back up. But after a little testing and my first trip, I am very pleased with their strength. Make sure to wet the suction cups first!!! They hold much longer this way.
I was trolling some lead core line, going after rainbows and Kokanee. You don't really feel the added weight or drag of the gear behind you, but the turning radius is affected.
I chose to run the suction cups parallel on the board which I like the best (most of the pics show perpendicular). I also decided to run the rod in front of me for strike indication and ease of removal, I was able to angle it right so it didn't affect my paddling. Overall I like the quality and strength of this project. Good luck!
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    Nice solution! Looks sturdy and very well done.
