3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sudoku:solving it for beginners and the expirienced
I will be showing the most basic to not so basic methods,trick and tips to finish a sudoku.this instructable is for anyone who plays or wants to play sudoku even if you don't know how to play.
I'll start with the basic thing and progress to the less basic things.
Step 1How to play sudoku
How to play sudoku
The objective is to fill a 9x9 grid so that each column, each row, and each of the nine 3x3 boxes (also called blocks or regions) contains the digits from 1 to 9.
A cell is the smallest block in the game. A row , column and region consists of 9 cells and the whole game consists of 81 cells. A region has thicker lines surrounding it. This simply makes it easier to play the game.
8 comments
Oct 6, 2011. 11:32 AMRabidAlien says:
Nice instructable! I was thinking about writing up something like this, but am about as far from a mathematician as one can get, so I never really got around to it. I call my "rules" the "Two of a Kind" (two of the same number, in adjacent columns/rows that narrow down the placement in the third row of that set of horizontal or vertical blocks), two pair (two pairs in a row, column, or a block, eliminate all numbers in that associated row/column and/or block....three triples is the same, but with three numbers, and I find it more difficult to use this rule, and it shows up a whole lot less, I find; besides, the other rules usually trump the 3-Trips), and "Three-Pack" (all three numbers in a row/column within a block are filled in, this allows placement of single numbers of adjacent rows to be placed in the other two blocks in that row/column of blocks). I find that, with a minimum of WAG's (Wild @rsed Guess), I can usually plow through the hardest level of the Sudoku app on my Droid3 in about 15-20 minutes.
Apr 30, 2010. 10:36 AMajjardin says:
Sudoku is a fun game to get into. all the different Sudoku Strategies can really work the brain. a great past time
Dec 6, 2008. 3:09 PMcross-eyed beginner says:
I am a beginner at this little brain-tease, and have discovered a solution that will save the masses from the madness of that one grid that cannot be solved; take a black marker and change things to suit yourself.
Sep 24, 2007. 5:32 AMProject_Nightmare says:
Wasn't this instuctable done already? They also suggested the same method
Sep 24, 2007. 3:41 AMPatrick Pending says:
WRT: Step 5 I understand the logic of the numbers but not what you were saying about "x,y,z". Did you miss something out? Cheers, Pat. Pending
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Oorspronklikheid
