3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sugru Basics and Tips
Because of the contest, I got my hands on some Sugru and it's pretty awesome. I've found a bunch of tips and basic instructions, but felt that they needed one place for newbies to read - especially the information that is useful to any project. I'm a newbie myself, so anything I find useful will be included. If anyone discovers any tips that I don't have listed, please comment and I'll add it to the Instructable.
The official website can be found here: sugru.com. You can buy it from the website and shipping is pretty cheap (a couple of bucks US) to anywhere because the packs are pretty small.
The technical data sheet is here: http://sugru.com/pdfs/FORMEROLsugru_TDS_OCT09.pdf
There is a plethora of information on this site: http://getsatisfaction.com/sugru/
And...here's their Facebook page: www.facebook.com
Step 1What is Sugru?
What is Sugru?
Sugru is awesome new stuff that seems to be able to do just about anything. It starts out like a modeling clay and turns into silicone after 24 hours. It will hold its shape but stay flexible and it bonds with almost anything.
It's waterproof and can withstand lots of temperatures (-60 °C to + 180 °C according to the website - that's -76°F to 356°F). That means when it's cured, you could use it in the snow and it can withstand boiling (but It's not food grade - don't use it on surfaces where it's going to touch food a lot)! Wow! It's also dishwasher-proof.
Is there anything this stuff can't do?
31 comments
Sep 13, 2010. 1:13 PMjen7714 says:
You should probably add that Sugru can't be used on surfaces that have to stand a lot of wear. So you can't use it on the bottom of shoes and such (which really stinks because I had a awesome idea but now I can't since I found that out).
Sep 15, 2010. 11:48 AMmwfaniej says:
Please what is sugru?
we in south africa might have another name for it
thanks Fanie
Sep 16, 2010. 11:10 AMmwfaniej says:
Thanks for the quick response and explanation
regards Fanie
Oct 31, 2011. 9:19 AMhanlie says:
Hey Fanie
I live in Cape Town and ordered mine online, quite cheap but it took about 10 days to get here. It's amazing stuff though, get some and start playing.
Jul 16, 2011. 3:52 AMmonkey_uk says:
I've found that Sugru will stick to almost any plastic, but sometimes you need to roughen the surface of the plastic with some sandpaper first. Failing that, if for any reason it falls off, a bit of superglue can hold it in place.
Feb 24, 2011. 10:50 AMangelabchua says:
Question.... I used sugru and a paper clip to replace the zipper pull on my jacket. Well now it comes time to wash said jacket. How will the sugru fare in the washer and the heat from the dryer?
May 9, 2011. 7:20 AMpaperclip32 says:
The sugru will fare fine.It's waterproof and heat resistant up to 180 deg. C.The paperclip on the otherhand,may not fare as well.
Dec 31, 2010. 9:24 PMFruitbytheFace says:
The power of......Sugru? (Mighty Putty)
Dec 10, 2010. 6:50 AMwiredcur says:
Thanks for the Sugru primer. I'm looking to make a male-plug on the DC-side of a power supply but the only mold I have is the actual female side on my camera. I'm not really ready to put soapy water or oil on my camera. Have you found any other stuff that Sugru doesn't stick to?
Thank
Sep 16, 2010. 8:31 AMShesu says:
Hmm, sounds similar to the rubber stuff you can dip tools into, except this stuff you can mold into the shape you want.
I don't suppose you can mix it with something so it cures a little stiffer? I have a project where I used a 2-part epoxy clay, but it cured too hard, and I'm afraid this stuff might be too soft.
Dec 10, 2010. 12:36 AMpcwhalen says:
That "rubber stuff you can dip tools into" is very cool. The two products are VERY different, but can do some of the same stuff.
I fixed an attachment to a hose thread. With the dip, I had to use masking tape, sugru was much easier to apply. Simply put: dip is cheap, messy and fumey where sugru is pricey, controllable and relatively fume-free.
My policy with both is where you need a lot of material to do a job and it doesn't need to look good, dip is king. Where smaller, more refined work is required, sugru is the material. The aesthetic of the material is cool.
Finally, dip coats, sugru molds. If you want to insulate lots of wire: dip. If you are modding a computer and finishing off cable sleeving or smoothing out zip-ties, vanity requires sugru.
Sugru joins WD-40, double sided Velcro, duct tape and zip ties as my favorite things. Add some telephone wire and some spit and you can make a submarine using only those materials.
I just ordered my 3rd assorted color bag.
Sep 17, 2010. 8:08 AMShesu says:
Hmm, I guess I'll have to try it then. Thanks!
Sep 27, 2010. 5:47 PMred211 says:
where do you get it
Oct 1, 2010. 6:42 PMred211 says:
ok
Sep 21, 2010. 1:35 PMgamemasterful says:
Thanks so much! I was wondering if Sugru was conductive. I'm assuming you mean after it has cured. Any confirmation on before it has?
Sep 19, 2010. 12:20 PMmotleyjust says:
What kind of store, or which department. do you find it in?
Sep 19, 2010. 7:15 PMmotleyjust says:
Thank you
Sep 19, 2010. 1:55 PMdombeef says:
Does it stick to silicone?
Sep 19, 2010. 6:26 PMdombeef says:
Ok, thanks!
Sep 15, 2010. 9:26 AMsunshiine says:
Thanks for posting this! Great information.
Sep 13, 2010. 2:11 PMmary candy says:
here in Brazil, I can't find it in the Stores :(
Sep 13, 2010. 2:21 PMKiteman says:
They do mail order, and it isn't heavy.
Sep 13, 2010. 2:20 PMBrittLiv says:
you can buy it online: https://sugru.com/buy/
shipment to Brazil is $1.89
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:jwystup(Professional Site)
I am a computer programmer. I like to cook and make awesome things.
