I have been looking for a way to cary my knife around & have it quickly accessible, but couldn't find the right case. So I made this nice knife caddy/case that I can quickly pull my knife out of, & then put it securely back in. (Great for on a hicking backpack & on your pants belt-loop for everyday use) This design can also be used with cases for phones, small flashlights, keys, etc.....
Step 1: Supplies
The supplies are pretty simple and wont cost you alot.
Supplies:
-A knife or other object to make caddy/case for.
-Sugru, I used 10g of sugru for my caddy, but amount may vary depending on size of caddy.
-Plastic Wrap (to keep sugru from sticking to knife)
-Soapy water (to keep your hands from sticking to the sugru when smoothing it out)
-Carabiner hook (to clip to backpack or pants)
-Straw or other cylindrical object (to make hole for the hook to go through)
-Tape ( to tape plastic wrap to knife)
Step 2: Preparing the knife
Preparing the knife is simple, all you need is some plastic wrap to cover the knife in ( to keep the sugru from sticking to it). Take the plastic wrap and slowly pull it over the knife so that it stays perfectly smooth, & then tape it on tightly. If you want the caddy to be attached to the knife permanently you can for get this step!
Step 3: Forming the caddy
Now comes the fun part, you can design the caddy any way you want! Take some of the sugru and start molding the caddy onto the knife (try to keep the thickness the same through out the caddy). Then once you get the basic shape you want dip your fingers into the soapy water and start smoothing the sugru out, or for a different look & feel you can add a nice dimply texture to it by rolling it on a towel ( I chose the smooth method).
Step 4: Forming the hook loop
This part was the biggest pain for me, but once I switched from using the screwdriver to using the straw it became much easier! You need some cylindrical object a little bigger that the diameter of your carabiner (I found a straw works best). Take the straw and dip it in the soapy water and then take the rest of your sugru and form the top of the loop over the straw, then continue smoothing all the sugru together to create a nice evenly smooth surface. Then once you have it how you like let it sit for 24 hours.
Step 5: Finishing the caddy!
Once the sugru has sat for 24 hours remove the caddy from the knife and then pull the straw out of the loop, & pull all the plastic wrap off of the knife, then just put the carabiner in the loop and walla you have a very knice portable knife caddy! This caddy design works great so you can quickly pull out the knife and then put it securely back in. This caddy deign will work for far more than just a knife, what about a phone, small flashlight, keys, etc........
Where can I find an awesome knife like that?
definitely not legal in california.
http://en.wikipedia.org/wiki/Switchblade#State_laws
According to that, this knife would be legal in California if the blade length is under 2 inches.
http://www.youtube.com/watch?v=T1lBmvVIX-o
This one springs out, but you have to manually pull it back in. Seems kind of impractical to me because the spring is only one way whereas a regular OTF switchblade's spring works both in and out.
Hope this helped.
They don't dry to rubbery substance like sugru (well, I'm not exactly sure what sugru is like but dried gluestick isn't anything that can be described as nice :P)
Sorry for misunderstanding :)
here's all the info you need
Does anyone know of any way I can get one of these in the UK (I'm not to bothered about knife laws), would anyone be prepared to send me one from the USA if I paid them (paypal).
