Suitcase for Material
6,609
192
4
Posted
Introduction: Suitcase for Material
Because I limited my desk space, and have a desktop stand but hit the roof diagonally where my desk is located, I decided to make myself a lectern table of about A3 size.
Not completely satisfied with my result, transform it into a suitcase to transport materials and also serves both lectern, variable angle.
Debido a que me limitaba el espacio de mi escritorio, y al contar con un atril de sobremesa pero chocar con el techo en diagonal donde se ubica mi escritorio, me decidí a a realizar yo mismo un atril de sobre mesa de tamaño A3.
No satisfecho del todo con mi resultado, lo transforme en una maleta para transportar materiales y ademas sirve a la vez de atril, con angulo variable.
Step 1: The Desktop Stand
The first thing I did was made the desktop stand.
This is made up of two wooden boxes made of wooden sticks 90 square mm, and approximately 35 cm high and 49.5 cm wide, joined at the base of 49 cm by 2 hinges; the deck is cut and adapted to these measures Cholguan. Fixing system for a set was made in one of the frames in the most narrow sides of the frame, in this case would be 35 cm; to operate as a rail. Then inside frames a stick of 90 mm and 21 cm long at a distance of 11 cm is screwed from the edge leaving its fixed position but allowing its oscillating movement and the opposite end is perforated to let a pin 1/4 x 3; which you will have movement within the "rail" fixed with a wing nut to give precione and set the desired angle.
Lo primero que hice fue realizar el atril sobre mesa.
Este esta elaborado por dos cuadros de madera hechos de palos de madera de 90 mm cuadrados, y de 35 cm aprox de alto por 49,5 cm de ancho, unidos en la base de 49 cm por 2 bisagras; la cubierta es de cholguan cortada y adaptada a esas medidas. Para el sistema de fijación, se realiza un calado en uno solo de los marcos, en los costados mas angostos del marco, este caso serian en los de 35 cm; para que funcionen a modo de riel. Luego por dentro de los marcos se atornilla un palito de 90 mm y de 21 cm de largo a una distancia de 11 cm desde el borde dejando su posición fija pero que permita su movimiento oscilatorio y en extremo opuesto se perfora para dejar pasar un perno de 1/4 x 3; el que tendra el movimiento dentro de el "riel" fijado con una tuerca mariposa para poder dar precion y fijar el angulo deseado.
Step 2: The Suitcase
For the preparation of this the steps are very simple, since only consists of adding the cover to the rear frame.
Then add the strap and handle, with thin slats later separations are made with a simple assembly system.
At the end of which incorporates a magnet closes to secure the closure of the suitcase.
And presto !! Your suitcase for longer carry and draw anywhere.
Para la elaboración de esta los pasos son muy sencillos, ya que tan solo consiste en agregar la tapa al marco posterior.
Luego agregamos la correa y la manilla, mas tarde con tablillas delgadas se hacen las separaciones con un sistema simple de ensamble.
En el extremo de donde se cierra incorpore unos imanes para asegurar el cierre de la maleta.
Y listo!! ya esta tu maleta para transportar y dibujar donde quieras.
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    5 Comments
    Great looking brief case. Y gracias port las traducciones.
    thanks, this is my first proyect of many to post here, and i feel so happy with all the great comments ;).
    Time to get inspire!!
