Introduction: Summer Yarn Hat
These hats I made at the beginning of my summer holidays. The inspiration I got in the technique we learned in our arts class in school for making yarn ornaments. For the small one it took me two days and for the big one, since I had to roll the thread to get the design I wanted, I needed 5 days.
Materials
1) Different colored yarns (2-3) , about 30m total length
2) Wallpaper glue (in powder, dilutes with water)
3) Wider painting brush
4) A pot to mix the glue in
5) Aluminum foil, less than 2m (The ticker the foil is the better, because it is going to peel off easier at the end.)
6) A bowl
7) A needle and a thread to sew parts of the hat together
8) Scissors
9) Some damp cloth or paper towels to wipe off the hands
Step 1: Mix the Glue
Put wallpaper glue powder and water in a pot, then mix a bit and leave it for two hours to make a compact mass. (In my case it was a local Serbian wallpaper glue brand, that is on the image). In the beginning there will be lumps in the mass. If there are still lumps after two hours, you should mix it until the mass is smooth.
Step 2: Prepare the Bowl (the Shape for the Crown of Your Hat)
Find a bowl that fits your head, than put aluminum foil around it. Make sure that the foil doesn't move from the bowl.
Step 3: Start Putting the Yarn
When you are done putting the foil around the bowl and your glue is ready you can start fixing the yarn over the foil. You have to spread some glue over each new piece of thread you put over the foil.
(A hint: do not put too much thread, the hat will be heavy for wearing, neither put too little, it could easily break.)
This will be the crown of your hat. Make the side parts of the crown as long as you wish. Make sure that you have common edge on all of the sides. You can do it by putting yarn two or more times around so that it makes a firm edge of the crown. Later on you will sew the brim to it.
Leave the yarn and the foil over the bowl until it firms.
Step 4: The Brim
To make the brim of the hat put the foil on a flat surface. Then adjust the hole in it to fit the circumference of the crown, leave additional centimeter inside. Think of how wide the brim should be and perhaps you would like to adjust the width of the foil.
Start putting yarn and gluing it down to the foil as you previously have done with the crown. At the end you might want to put some additional line of thread to both edges of the brim to get them hold the shape of the brim once the foil is removed.
Let it dry and firm.
Step 5: Remove the Foil and Sew the Parts Together
When everything is dried, peel off the foil from both the crown and the brim. (Maybe not all of the foil will be removed).
At the end sew the crown and the brim with adequate yarn or thread together.
Step 6: And Voilà, Enjoy Wearing It!
Note: These hats are not waterproof. I am thinking of using different type of glue for the next one. (Any suggestions for the glue?)
Because this is my first instructable ever, I would like to get the feedback and comments on the quality of the instructions.
7 Comments
Well done Iskra!
Creative and fashionably designed! Will have to make it at home, but will need a lot of material for my size though.. :)
Thanks!!!
Not only for summer - these hats are great for some costume plays in theatre...
Thanks,good idea!!!
This is really cool. I have a feeling that Jackson Pollock should have worn hats like this.
Thanks, this is really encouraging!
