Sumtonian Dremel Router and Dremel Router Table
Published
Introduction: Sumtonian Dremel Router and Dremel Router Table
Sumtonian Dremel Router and Dremel Router Table picture itself is full of explanations as well as illustration. Picture illustration does almost all description required for the construction of this very useful Router Base for dremel.
Fixing this on a table from below you get a dremel router table.
Step 1: Fixing a Dremel Inside the Collar.
Fixing a Dremel inside the collar and tightening the adjustable clamp is the first job. Next you place the this Dremel with collar moderately tightened (Over tight will break the the plastic body of your dremel !!!) in side the diverging Dremel router base prepared, adjusting the height of the tool according to your tool feed requirement
Now ensure the grip of this diverging base on dremel collar assembly by tightening the Snug Screws provided as shown in figure illustrations.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    3 Comments
    Made of strong plastic more than enough for dremel or mini die grinders.
    Frequently check fastening screws and clamps before operating the rotary to ensure fool proof.
    Thanks for comments
    Interesting and skilled project, as many of your instructables are! My only concern is cracking the housing or the screws vibrating into the shaft and motor. Has the design held since you created it?
    Positive or negative, comments are welcome
    for further developments !!!
