3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sun Bottles
Sun Bottles
  • last photo ←
AKA: Solar powered walkway version 2
This is my second use of a distributed solar lighting system, where the panel can sit somewhere in the sun and send power to the lights that are in a shaded spot.  I guess its kind of a half step between solar garden lights and wiring your home for solar power.  The result in this case is a single panel mounted to a sunny spot on a wall that sends power to a string of glass bottles underneath a grape arbor.
At some point after I built my Solar Powered Walkway, my brother and his family came over for a visit. Everyone seemed quite impressed with the lights, especially his wife. Ted had just finished building a massively oversized grape arbor for the gigantic grapevine that's been cluttering up his backyard for the last several years, and Michelle asked if she could have a set of the lights to put under the arbor. I thought this was a great idea and told them that if they paid for the materials I'd be happy to build something for them.
Of course, since I'm never happy to just leave well enough alone I decided the original design could use some work. So, I started tweaking things, a little here, a little there, and soon enough the result was something quite different from my original design.
About halfway through building this I got to thinking about the fact that I never get my sister-in-law anything for birthdays and Christmas, as I'm never really sure what she'd like. I am awful at buying presents for people. However, here I'd been presented with something that I knew for certain she'd like, and her birthday was even coming up soon! I ended up finishing the build the week before her birthday, and presented it to her the weekend before her party so we'd have time to set it up in the arbor.
Step 1Stuff you'll need
Stuff you\
Some of this stuff you can buy from online stores, but other parts you'll have to be creative to obtain.
Most importantly, you'll need a set of solar powered Christmas lights. I used a set from dealextreme.com and then altered it to make it work for my purposes. If you don't feel like making some major changes to the electronics, I'd recommend you find a different brand. These were not the best quality, the brightness of the LEDs was somewhat disappointing, the battery they came with didn't work, and the solar panel wasn't able to charge any battery enough to run the lights for more than a few hours. That being said, I was able to make it bigger, better, and stronger with some work and extra parts.
If you go with a different brand of Christmas lights you may or may not need the following items, but if you go with the dealextreme lights you definitely will:
  • A solar panel that puts out about 2v@600ma (I built one out of fractured panels from Electronics Goldmine)
  • A pair of decent rechargeable NiMH or NiCd AA's, 1.2v@2500ma each
  • Around 150-200' of light gauge speaker wire
  • A 2xAA (or two 1xAA) battery holder wired in parallel, not in series (I hacked up some old electronic gadget and rewired it for this)
  • Some sort of case to hold your new solar panel (I built mine out of . . . well, you'll see that in a future step)
  • Some cedar boards (I used a single cedar fence picket)
You definitely will need:
  • Epoxy
  • Silicone sealant
  • Paper towels
  • Stiff wire
  • Electrical tape
  • Nails/screws
  • Krylon clear matte spray
  • Clear glass bottles/jars/vases (get them second hand)
As to tools, you'll need the usual assortment of modern tinkerer's tools:
  • Dremel
  • Hot glue gun
  • Hammer
  • Screw driver
  • Wire cutters
  • Pliers
  • Soldering iron
26 comments
Nov 11, 2011. 1:56 PMI am in the shed! says:
I see the term "goodwill" used a lot on here... would it be our version (in the UK) of a charity shop, where goods are donated to a charity and are then sold to raise funds for that charity.
Well done for the 'ible... very inspiring, we have a chain of shops in the UK called Poundland, everything is priced at one pound, and things like LED garden/christmas lights can be obtained here - very useful for us who make - do you have 1.59313 Dollarland I wonder?
Oct 5, 2011. 6:17 PMsolarstudent says:
If I had a solar cell that puts out 6V , 50mA would this setup work if I put the batteries in series or is that a current requirement that needs to be met in order for all of the LEDs to be lit up?
May 22, 2011. 12:57 PMKittyF says:
my problem is I don't understand the electrical terms. is it something I need to take a class for? is it something I could learn on the net? is it something I even need to learn or should I just follow the directions blindly and assume that I don't need to understand them?
I assume that this project will be a one off project without understanding though, so I always strive for understanding so I can use the ideas in another project.
May 24, 2011. 10:51 AMKittyF says:
I'lll have to look for that. it looks like it would be useful stuff to know. . thanks
May 23, 2011. 7:32 AMbwelkin says:
To those readers intending to make a similar project let me suggest that you use "heat shrink" instead of electrical tape to insulate your soldered connections. Heat shrink comes in many diameters; pick one just bigger than the twisted-wire-soldered connection will be and slide a two inch piece up one wire before joining your wires together. Slide the 'shrink down and heat with a lighter. Not only does it contract, the insides melt and coat your solder job with a weatherproofing kind of tar. It also make it a prettier job.
Nov 18, 2010. 12:08 AMantling says:
I totally liked solar projects and in the midst of coverting everything in my house to 12VDC and getting ready for all-solar-living (at least 80%).
in this instructible, the new panel you made consist of more than 1 "crappy" panels right?
how many to be exact? the shapes seems "off" can you tell me more on that?
Nov 19, 2010. 6:43 PMantling says:
Basically My wife and I had just bought a house and moved in about 3 months ago. Since it is a new house, we decided first hand to change all the concealed cable from 1.2mm to 2.2mm (I'm using BS in Malaysia). you may need to calculate suitable cabling size for your cables if you are interested in going solar.
Fundamentally, in Malaysia, our general standard domestic voltage is 240V. bty changing to solar, I am looking at all 12VDC without any means of inverter as it is additional cost to me.
My plan is simple and will take up a long time to conceive (5 years)
STAGE 1.
By reducing the voltage to 12VDC, we will expect all equipment to have to utilize higher current (V=IR). Hence to avoid meltdown or cable fault. we decided to check all cables and finally stage 1 is already completed. all our cables are now 2.2mm instead of local developer standard of 1.2mm. this is an easy step.
STAGE 2. - Let there be light.
Lamp and all basic utilities are now running on 12VDC with the help of a little 12VDC power supply (inverter).
My staircase and night lamp is now consisted of 12V LED only!
STAGE 3 - Important appliances.
AIR-CONDITION UNITS (it is average 89F here year round!)
FRIDGES, WASHING MACHINE, Etc... All new machine will be checked before purchase. Only machines with 12VDC compatible is sought. That means, go for machines that runs on inverter, 12/24VDC is ok... It is just about when I will take off the inverters and run in DC. (This is almost complete except for our fridge and washing machine, which is quite new and I made a mistake purchase based on cost and not forward compatibilty)
STAGE 3 1/2 - Calculation.
STAGE 4 - Purchase of relevant power generation equipments.
STAGE 5 - Installation of the PG equipments and power up.
STAGE 6 - (5 years later) My solar home.. :-)
24 hours climate control and off-grid... yippee!!!
May 22, 2011. 4:32 PMlancruz says:
You probably don't have to deal with home owners association. Where I live you can't sneeze without HOA giving you a hard time.
May 22, 2011. 6:08 PMantling says:
Then you should cover your nose and mouth when you sneeze! actually, you can always do it descreetly as a part of small DIY stuffs. Just think of it as hanging a new flower pots somewhere, and also, do it in small manageable steps so it doesnt attract too much attention.
Nov 20, 2010. 8:37 PMantling says:
You are right!
The cost may not be reduced, but the pain can be minimized.. LOL.
Handshake for a person that share the same thought as I am.
At this rate, I guess, not only Obama is going to screw up. My country is going backward. Yet, this is for another forum.
Let us be less depending on the grid and do our part for the earth.
Aug 13, 2010. 4:59 PMEngEC says:
Awsome man! Great idea for an instructable, glad you made it. And sure your sister-in-law had saw that delightful work. Thanks man!
Aug 12, 2010. 8:11 AMhuttarl says:
Nice project. But like many, I wish people would describe in more detail what a project *is* on the front page, before launching into the history behind it, who they presented it to, the materials needed, etc. Especially with an unclear title like "sun bottles". "Solar-powered walkway" helps, but it's not a walkway... My best guess at this point is that it's a string of solar-powered lights in bottles. But life is too short to read the whole instructable just to find out if it's something I would actually be interested in making.
Aug 12, 2010. 10:32 AMsaehn says:
But it's not too short to write out a complaint, is it? ;-)
Aug 14, 2010. 1:37 PMhuttarl says:
@saehn... touche. But with the complaint, I have the chance that the author will clarify the 'ible (which he did), and save time for both me and a bunch of other readers. Maybe it will even help influence other authors to make their front pages clearer.
@depot, thanks for being responsive! The pictures somewhat spoke for themselves, but they were mostly close-ups, so it wasn't clear what the big picture was. Much better now, with the extra pics and expanded description! Thank you.
Aug 12, 2010. 7:00 AMnicholas1951 says:
Very interesting and full of possibilities for different uses. Nice job. Thanks!
Aug 11, 2010. 7:17 AMPedalit says:
Great idea! It reminds me of solar indoor lights. In places with no electricity people hang water filled bottles in the ceiling. The light refracts and illuminates the structure. P.S. It rains a cumulative 5 days a year where I live. We only have a roof on our house so the sun doesn't catch us on fire.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
306
Author:depotdevoid(depotdevoid on Facebook!)
Like me on Facebook, my poor, fragile ego needs a boost! I post updates about my current projects, and the occasional sneak peak at upcoming instructables! ...
more »
