Sun & bug lotion: one simple solution
Step 2Ingredients and where to find them
Water mix:
1/3 cup witch hazel (or 5 tbsp if you do not use coffee)
2 tsp fresh coffee grounds (optional)
Oil mix:
1 tbsp coconut oil
1 1/4 tsp ewax
1/2 tsp Neem oil
1/2 tsp sesame oil
2 tsp cocoa powder (optional)
Powder mix:
1 tbsp zinc oxide (quantity can be doubled for extra protection)
1 small pinch xanthan gum (do NOT omit)
1/2 tsp turmeric (optional)
Additives:
1/4 tsp vitamin E
1/4 tsp essential oils (combination of citronella, eucalyptus and lavender, but pennyroyal and peppermint can be used too)
Note on ingredients:
Coconut oil, sesame oil, vitamin E, zinc and turmeric are all "sun" ingredients. Turmeric (a yellow spice you'll find in any supermarket) was used as a cure all in Ayurvedic medicine, but since those guys also believed diseases were caused by demons and that you can wish yourself not to age, I included it here for other reasons: #1 color. I prefer to look sickly yellow rather than zombie white (the coffee and cocoa are also here to improve the color). #2 according to wikipedia turmeric is used in sunscreens and to protect foods from sunlight. If it keeps a pickle nice and firm, hey, maybe it'll keep me from getting flabby! Now I'll just close my eyes and wish for eternal youth...
Neem oil, witch hazel and the essential oils are the bug ingredients. Neem is a dark oil with a smell somewhere between garlic and peanuts. Unpleasant at first, but it grows on you. It's kind of comforting, like the smell of farts under bed covers.
Xanthan gum is necessary for three reasons: it thickens the lotion so it will not run all over when you try to apply it. It stabilizes the emulsion (keeps the water from separating), and it keeps the zinc oxide suspended in the lotion. Don't be fooled by the small quantity required: you need it.
Ewax is another crucial ingredient. The E stands for emulsifying, and it's purpose is to blend the oil and water into a smooth, stable cream (you might find it under the name "emulsifying wax NF" in online stores. It comes in white, waxy flakes which are easy to measure and melt. It is not considered "all natural" because it is composed of a blend of cetearyl alcohol and polysorbate 60.
Soap Goods supplies all the above ingredients and it might be easiest just to order everything from them, but I found my xanthan gum in the vitamin section of my local Fairway for less (however considering the time spent searching, and the cost of transportation, the savings, if any, are negligible). I would definitely buy the witch hazel from a local pharmacy, and the coconut and sesame oils from a grocery store because they are widely available and heavy to ship.
18 comments
Jun 18, 2011. 1:50 PMdbarrett squires says:
Do you think it would be possible to replace the e-wax with lecithin? I have used lecithin in a cream soap before with good results, just not sure how it would react with these ingredients -and don't have a tonne of money to waste testing the theory :-)
Jun 4, 2011. 2:02 PMidleFLUX says:
oh man I just tried to post a really long comment but it didn't work -____- anyways, I was just saying that I'm so glad I found your post and had a couple questions!
-I love using Nutiva's organic, unrefined, cold-pressed coconut oil, which is solid at room temperature. Do you think this e-wax and other ingredients all mixed together with this type of oil will keep it emulsified and from clumping together?
-which zinc oxide on soapgoods.com do you use? I searched and found two for sale. one says "zinc oxide usp" and the other has "kodax 911" in the description... o_O
-does the vit. e act as a preservative also?
-as far as using this at the pool/beach, how often when swimming should I reapply? or is there another type of wax or something like lanolin/vegan alternative I could add to it to make it more water..durable?
I plan to make my own version of this for everyday use since I'll be moving to Florida next year with some replacements to the bug oils like lavender and geranium but would still like to have a nice reliable batch for when I go swimming. After researching sunblocks(which is how I stumbled upon your post) I just can't find a good brand ...or one that I can afford for regular use since I go swimming a lot !!! Sorry about all the questions.. :3 you just seem like you know what you're talking about :]
Jun 10, 2011. 4:51 PMidleFLUX says:
thanks for the response! i just signed up for the newsletter :D and ya, the main reason I asked about which zinc oxide you use is because I DON'T want the nano sized xD i'll def be emailing them! and i think i'm going to try beeswax instead because i want to be as "natural" as possible :P
May 15, 2011. 7:00 PMnbullock says:
i'm not crazy about the smell of neem..... could i leave it out and just use the other essential oils?? thank you so much for this post!!!
Jul 18, 2009. 7:14 PMmobilediesel says:
You can use Z-Cote Zinc Oxide Translucent zinc oxide which provides maximum UV protection but without the extra whitening typical of zinc. I get it at tkbtrading.com
May 24, 2010. 4:18 PMteeps says:
Here's the manufacturer's brochure on Z-Cote:
www.solsunguard.com/zcote_brochure.pdf
Here's the tkbtrading page.
It appears that Z-Cote is exactly the new nano zinc that you cautioned against on the previous page.
According to this: answers.google.com  The average pore size is 50 microns, which is much larger than the .2 micron Z-Cote or the .12 micron sized regular zinc oxide (this is the size of the product Soap Goods sells as well (pdf) )
According to this dermatology website, the micronized particles like Z-Cote can be potentially hazardous, but they also say that micronized particles coated with Dimethicone help to alleviate some of these risks.  On that same TKB site, they offer HP1 Z-Cote which is exactly that, coated with Dimethicone, for not much more money.
OK, that's enough research for now.  Anyone want to chime in?
May 1, 2011. 9:47 AMsfromer says:
I'm a bit scared off by all the comments about how dangerous the powdered form of zinc oxide is. Can you substitute a 40% zinc oxide cream (the highest I've ever seen at a drug store) for the powdered zinc oxide, and in what proportion? I'd love to make a sunscreen without the bug repellent...
May 1, 2011. 1:49 PMsfromer says:
I know the 40% zo cream could be used as is, but it would be a horrible mess; I'm wondering to make a commensurate sunblock as the one you'd talked about, if I could mix some of the zo cream with a moisturizer base to come up with an easy sunsafe solution that was spreadable (albeit a little white). Just not sure how to translate the dry zo with the 40% cream...
May 24, 2010. 10:18 PMteeps says:
Whoops, forgot the link to the dermatology site.  Seems like a dense site overall, with plenty of other areas of research represented, including some info on supplementation at the bottom of the page linked above.  There's also some interesting info on various other ingredients that companies add to their mixtures such as Niacin and Green Tea.  There's even an article called, "How to Be a Skin Care Failure", which includes a long rant against "natural" product manufacturers.
Have you ever heard of adding Green Tea in this form to a DIY skin care product?
This blurb implies that other forms of zinc are good for the skin, but that zinc oxide is the only one not actually absorbed.  I wonder if adding an alternate form of zinc would make a good addition to a formula.
Lutein, anyone?
I don't want it to seem like I am plugging this site, there's just a boat load of info there that I have been wading through for a few hours now.  I realize that a lot of this goes into creating much more than simple sun screen :)
May 27, 2010. 12:05 PMteeps says:
I am eager to hear your conclusions.  It's a real rabbit hole, this skin care topic.
Jul 5, 2009. 9:49 PMEaglesNest says:
What is "ewax"?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
238
Author:belsey
I am trying to work on an overly ambitious tome, MAKE ANYTHING, a handbook for saving money, living green and having fun with trash. Trouble is, I keep getting distracted by pop-ups -- the cards, not ...
more »
