Step 4Use and warnings
I once came across a ridiculous web page written by the Soap and Detergent Association, clearly on the defensive about the rise of DYI -- but one point they made about labeling really does make sense. It is dangerous to have ANY sort of chemical product mislabeled in a recycled container. It is important not only to remove the old labels but also to put on your own, preferably with a detailed list of all the ingredients and first aid instructions in case of accidental misuse. So if you try out my recipe, please print the attached PDF file and use the label (or design your own if mine isn't colorful enough -- I designed mine to look as dull at the real ones).
Warning for people with allergies or sensitive skin: do a patch test before slathering this on. It is quite possible that you would tolerate Deet much better than this -- after all, the vast majority of allergens are 100% natural, 100% organic. Think pollen, dander, nuts, strawberries, mildew.... To test individual ingredients, mix them with something you won't react to (like good old synthetic vaseline) in a concentration roughly equivalent to the concentration in the recipe (1 drop of essential oil mixed with 1/2 tsp mineral oil or vaseline, for example) and dab that in the crock of your arm. For extra peace of mind, do this every day for 2 weeks to make sure you will not become sensitized over time.
A final note on longevity -- it is impossible to give a definite shelf life time frame because too many factors are in play. The first and most important factor is how well all the containers, tools and fingers which come into contact with the product have been sanitized. Ideally, dunk everything (except for fingers) in a pot of simmering water for 15 minutes. That's how I do it when I make jam, but it's not always practical for lotions (the recycled PET containers I use tend to get deformed at those temperatures...). Just clean everything as best you can. Another factor is how fresh your ingredients are. Still another, what ingredients you choose (my coffee/cocoa version, for example, might have a shorter shelf life than the version using straight witch hazel). Finally, whatever spore is floating around in the air or organism is living on your fingertips when you open the bottle might jump in and start a thriving colony.... This is why I usually make small batches or use preservatives. That's right. There's nothing wrong with adding a small quantify of preservatives, in fact, I highly recommend it if you are making any lotion as a gift. I have used Liquid Germall Plus, a paraben free preservative which seems to work quite well. All you need is 0.1 to 0.5% of the total weight, which translates for this recipe to about 3 drops.
Bug and sun lotion.pdf(612x792) 811 KB| « Previous Step | Download PDFView All Steps | Next Step » |
Add Comment
