Sunflower Wreath
378
4
4
Published
Introduction: Sunflower Wreath
The sunflower can mean something different to everyone. They are a symbol of perseverance, as they can handle drought, heat, and tough conditions and still shine. They represent strength with their upright and strong stem, holding a lot on their shoulders. They are seen as nourishing, as they provide food. Or to some, sunflowers are just a symbol of warmth, positivity, and happiness as they always turn to face the sun. This sounds like a lot of women in our lives - our mothers. When designing a gift for my mom for Mother's Day, I wanted to give her something that represented those qualities; here is an everlasting sunflower wreath.
To my momma bear: thank you for being everything I need and always more. Happy Mother's & Father's Day.
Step 1: Materials
  • 2 yellow fabrics (yellow batik)
  • Brown fabric
  • Green fabric (leaf batik)
  • Iron-on stabilizer, medium weight (I used Pellon 809)
  • Yellow & black thread
  • Petal, leaf, & center template, printed
  • Scissors
  • Rotary cutter, ruler, mat
  • Friction pen
  • Small black beads
  • Poly-fil
  • Sewing machine
  • Iron
Step 2: Make Petals
    Cut the following:
    • Yellow #1 (12): 6.5" x 6.5"
    • Yellow #2 (12) 6.5" x 6.5"
    • Brown (12): 2.5" x 2.5"
    • Stabilizer (12): 6" x 6"
    1. Side #1: this processing is also called "snowballing"
      1. Grab stack of brown squares
      2. Press squares in half, creating a triangle
      3. Place square on the corner of a yellow square
      4. Open the brown square and sew a straight line along the crease
      5. Trim off 1/4" to the right of the stitch line
      6. Open and press
    2. Side #2:
      1. Place stabilizer, shiny side down, onto wrong side center of 2nd yellow - there should be equal space on each side of the yellow block
      2. Press - according to directions - until stabilizer is attached, and let cool
    3. Finish petals:
      1. Place side #1 & side #2, right sides together, and sew 1/4" seam around the block; backstitch at the beginning and end and leave a few inches open to turn block inside out
      2. Cut off the four corners without cutting the seam (easier to turn), turn inside out, use a turning tool (or chopstick) to push out corners, put raw open edges to the inside, and press the petal square
      3. Top stitch an 1/8th" seam around the block
      4. Using the Sunflower Petal template provided, place the cutout, skinny side toward the brown, and mark with friction pen (or chalk). Keep the "up" side facing upwards on all blocks, as the pattern is not perfectly symmetrical. Even if the template is too big or small for your 6" square, it doesn't matter as long as you keep the small point lined up with the brown corner point
    Step 3: Finish Petals
    1. Attach petals:
      1. Place two blocks "side #2" together, making sure brown points are in the same corner
      2. Sew the two blocks together using one of the template lines
      3. Open up the two blocks and repeat with a new block, now using the other template line. Keep adding blocks all the way around the wreath until you finally sew the last two together
    2. Decide which sunflower look you like better: The points of the petals need to be secured; you can either sew the petal points to the other point on the same petal, or the one right next to it. They give very different looks. I went with option two!
      1. Hand sew or use machine to sew corners of SAME petal together
      2. Hand sew or use machine to sew adjacent petal corners together; use iron to create creases. You may even need to use fabric glue to keep petals from falling
    *You could be done after this step and not add the brown center or leaves if you wanted to use this as a table centerpiece.
    Step 4: Sunflower Center and Leaves
    1. Center:
      1. Use Center template provided to cut out (2) brown circles and one batting circle
      2. Lay browns right sides together with the batting on top, and sew circles together leaving a 2-inch gap opening
      3. Turn inside out and press
      4. Hand sew on black beads through only the top fabric; the flower opening is small, so keep the beads close to the center
      5. Place brown circle underneath the center of the petals and mark with a clip or pin where your brown center opening is; you will stuff this with poly-fil later
      6. Sew inch (or so) sections around the circle as pictured
      7. Add poly-fil to your desired lift; this is added for depth
      8. Finish sewing brown circle
      9. Decide if you want to leave the petal's brown points laying flat (#1) or flipped up (#2) (I did this!); they both provide different looks
    2. Leaves:
      1. Use Leaf template to cut out (4) green leaves
      2. Sew two leaves, right side together, flip inside out, and press
      3. Fold leaf in half, use your friction pen to mark a two inch line up from the base, and sew a 1/4" seam from the folded edge; this gives the leaf some movement and depth
      4. Top stitch an 1/8" seam around the edge of the leaf
      5. Position leaves in desired placement and sew onto petals
    Step 5: Give to Your Momma!
    You can either leave as is and hang on the wall or you can hot glue on a wire wreath frame to hang on your front door!
    Flowers Challenge
    This is an entry in the
    Flowers Challenge
      • Spotless Contest
        Spotless Contest
      • Slow Cooker Challenge
      1 Questions
      I actually have never had to wash one, so that's a good question. The storm door does a good job of keeping the front door wreath clean and rain free. However, if it did get dusty, you could take a lint roller to it or, even preemptively, try scotch guarding the wreath and wipe it clean thereafter. I haven't needed to try that, however. Now, if you leave it as a table centerpiece and food or drink gets on it, you could use a wet cloth or tide-to-go pen to rub it off. I would not recommend washing the wreath!
      4 Comments
      Wow! I wish I could’ve given this to my mom! I know what I’m making for next year!
