Pocketable Clip-on Sunglasses
Introduction: Pocketable Clip-on Sunglasses
Everything I use must fit in my pockets.  I should have sunglasses with me at all times, but putting them in my pocket is not a viable solution … until now.  My clip-on sunglasses disassemble into a pocketable package.
Step 1: Selecting the Sunglasses
To create them, use clip-ons that have a “3 rail” system. I got these at Walgreen's for about $15.
Step 2:
Now, with a dremel tool or a small file, cut notches in the holes where the rails slide through.  Be careful not to cut the spring as I did. It just makes it messy.  Cut the notches from the bottom up to the actual hole as seen in this picture.
Step 3: Disconnecting and Connecting
Now, the two pieces should be able to detach from each other and snap back together. Just make sure the spring stays between the two sliding pieces.
Step 4: Carrying Case
I made a simple wallet for the glasses by cutting the bottom off of a cheap, fabric glasses case. There are probably better solutions than this.
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    Not bad, but the name is pretty vague.
