Sunrise Lamp
342
7
Posted in WorkshopLighting
Introduction: Sunrise Lamp
Sunrise Alarm Lamp
The Lamp is controlled by a motion sensor in the base of the lamp. Put your hand in the middle of the circle and it will turn on and off.
The Lamp fades on at a designated time through the arduino code provided.
By Bridget Tangaere, Dennis Chu and Rosie Chote from Massey University CoCA, Wellington.
To follow our progress please go to: https://birdopendesign.wordpress.com
Electronic Components:
• Arduino Uno
• RTC (real time clock)
• Mosfett and Resistor
• Motion Sensor
• Power cord 12 volts
Material Components:
• 596.0mm x 291.0mm sheet of white acrylic 3mm
• 596.0mm x 291.0mm sheet of black acrylic 3mm
• 596.0mm x 291.0mm sheet of mdf 3mm
• 49mm x 380mm sheet of polypropylene 1mm
• 49mm x 460mm sheet of polypropylene 1mm
Step 1:
Download the 3 Illustrator
files named; (MDF.ai, white-acrylic.ai, black-acrylic.ai)
Step 2:
Choose a 3mm thick, 596.0 x 291.0mm material for laser cutting (if you are modifying the materials)
Otherwise use materials advised
Be aware of the strength of your material, a material which is quiet brittle will be prone to cracking when assembling.
Step 3:
Print files on laser cutter to matched material label
Step 4:
Download jpeg files for a map of your pieces.
Join parts 1a, 1b and 1c together with 2b pins, using a rubber hammer. 3f is the top middle pin. 3a sits on the outside of the frame.
Step 5:
5. Assemble the box frame with pieces 3b, 3c, 3d and 1c. 3e sits on the outside of the box.
Step 6:
6. Stick the LED Strips to either side of the pins.
Step 7:
Thread 49mm x 380mm sheet
of polypropylene into the inside slots of the circle frame. Thread 49mm x 460mm sheet of polypropylene into the outside slot of the frame.
Step 8:
Connect the circle frame to the base and slot in kerning pieces.
Step 9:
Attach lid
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    This looks cool! Are you going to post more about the lighting in it?
