Supa-Hula (a Very Big Hula-hoop Made From Plastic Electrical Conduit)
25,963
73
26
Posted
Introduction: Supa-Hula (a Very Big Hula-hoop Made From Plastic Electrical Conduit)
Toy Contest
Finalist in the
Toy Contest
Father's Day Contest
Finalist in the
This is a lot of fun and very cheap.
Here is a 20ft hula hoop with a 30 foot hoop.... it hurts my tummy.
Much more...
http://youtu.be/nTAWeofNgFU
Step 1: Materials:
Plastic electrical conduit.
It is 10 feet long and has a flare at one end that makes it a connector. (Also - I want this sweet pvc cutter)
Best luck with 2 pieces of 3/4"
3 pieces did not stay together but could be glued with PVC cement (the 2 part stuff that smells terrible)
A regular size hoop can be made with a 1/2" piece.
The conduit costs a dollar or two per piece.  It is extremely rugged stuff.
Step 2: Connect
Step 3: Bend
Step 4: Connect Other End
Step 5: Hula-Hoop
Give it a spin. It might break.
&nbsp
Step 6: 30fter
Here is a 3 part hula-hoop -- 30 feet around.
Needed to be glued together with PVC cement.
 Video with 3 pieces of conduit
Step 7: Jack Says Hi
Step 8: Hazel Has a Little One
Here is a 1/2" conduit.
Step 9: Have Fun!
They are also fun to roll and jump through.
Step 10: Molly Is Leaving
I meant to post this during the 2012 presidential election, but well... here we are.
Megs new blog
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
28 Comments
This is so cool. Do you think this material would support a vine? I'm planning on creating some privacy in my yard with four honeysuckle vines, and I really want the round shape but four round-topped arbors would be WAY too expensive. Gag. Do you think if each end of the conduit were attached to a fence post it would hold its shape? Thank you for your time!
It is probably too floppy to support from the sides. If you can hang it from the top center it could work. It is also slippery, but vines can hold onto most surfaces.
Is there a way to make this more stable? I'm wanting to use it as a base for hanging a large diy canopy. Thanks in advanced!
Try Fiber-Fix Repair Wrap from Home Depot or Lowes. When you wet the wrap it hardens like steel. You can wrap the wet wrap around the hoop and allow to harden, thus making it a stable, durable hardened hoop. However, keep in mind that the hoop will harden like steel and therefore should be applied and set inside the room you intend to hang your canopy (in the event it is too large to fit in the door). For removal at a later date you will likely have to cut through the hoop with an electrical tool. Make sure to reinforce ceiling hooks. I'm not sure how much weight it would end up being, but worth a try. You can try a search of videos for a demonstration or commercial on the product. I originally saw it on SharkTank years ago being demonstrated. Impressive stuff.
Hello! The Autodesk social media team loved your project so much that we included it in a post we created on BuzzFeed. Check out your work featured here: http://www.buzzfeed.com/autodesk/a-donkey-mask-lightsabers-daft-punk-helmet-cybo-b3y4
If you have any questions, please contact me at blake.menezes@autodesk.com
Best,
Blake Menezes
Autodesk Social Media Strategist
Your video was an inspiration, and it was fun and felt silly, especially spinning it up the first time. Thanks. What does your dog do when you're hooping?
I used a little over 20 feet of 1 inch inside diameter inch high pressure polyethylene line (the kind they use for submersible well pumps), and held it together at the ends with a scrap of 1 inch outside diameter plastic pipe and a few turns of gaffer's tape.
You're hooping at about 95 RPM, and mine is comfortable at about 60 RPM. I suspect mine is a little heavier.
my dog just watches -- she is laid-back
I've gotta' think about hoop size/weight vs RPM. I think is the size, with bigger slower. Heavier hoops seem easier.... angular momentum?
Hoop physics!
I've got some sunburned plastic electrical conduit lying around, so I'll give it a try, and see if the light-versus-heavy thing makes sense.
I think rigid is important in a hoop, and slower is better than faster for me, because my hips don't move that way very easily or very fast :-)
If your like me you could add"anymore" at the end of your comment. Ain't getting old FUN! ;-)
