Super Awesome Digi-Cinema Camera Rigs!!
 by MattosaurusRex
Contest WinnerFeatured
I'm a film teacher and photographer, and I've learned that most photo/video accessories are tremendously overpriced. This instructable will teach you to make a variety of camera rigs that can improve the technical quality of your images and digital video. Most or all digital cameras now have video capability, and these rigs are most useful for that application—shooting video on your point and shoot or dSLR. Included are instructions for a Cage/Fig Rig (AKA Mr. Shiny), a Lumber Dolly, and also some modifications on a sturdy and cheap, ready-made Shoulder Mount.
With these tools, you can document the most important things in the world—your inventions :)  ...and perhaps loved one's birthday parties and other required events, with extreme cinematic stye! Following is a little description of each rig built within this instructable.
Mr. Shiny is great for 2 reasons. First, you can handhold your camera more smoothly at many angles, allowing better and safer handling and smoother handheld shots. Second, if you have other accessories (like flashes, lights, microphones, etc) you can mount them all to it's frame.
The Lumber Dolly is a great little dolly. It can be used without a track, rolling on a smooth surface, or it can use lumber up to 6 inches wide. Here's a video of the dolly in use, with a tiny point and shoot camera.
The coolest thing with my design, is the SPRING MECHANISM. It grips itself to the board, and can be used with less than perfect, cheap lumber you find or buy for this use. One rail of the wheels is removable, and if you flip that rail over, you can have it ride the edge of a table or counter-top. Also if you just switch which side the mounting screw is on (effectively flipping the unit upside down), you can use this design on any smooth surface without a track.
The Shoulder Mount, is sort of a hack on a ready-made solution. The ROI on designing and building a DIY shoulder pad just wasn't worth it for me, but feel free to make your own of course! My modification is built on a self-gripping shoulder pad that is sturdy and cheap, and only $30 from Amazon (CowboyStudio Shoulder Support Pad). My modification makes it much more useful and customizable for the digital cinematographer. By customizing this design for your own cameras and applications, you'll have a cheap, extremely handy, and somewhat macho looking, piece of equipment.
Together, the professional versions of this equipment would cost over $1000, and you can build all of this for under $200!
The most expensive parts are actually the skateboard wheels and bearings, just so you know. I could have gotten a much better deal, but I was on a deadline when I built this...
Tools required:
1. Hack saw
2. Metal File
3. Needle Nose Pliers
4. Pliers or Crescent Wrench
5. Ruler + Sharpie
6. Hammer or Mallet
7. Dolly only: Jigsaw OR box-cutter + metal ruler.
Parts lists and sizes are included individually for each rig within this instructable, but here is a COMPLETE SHOPPING LIST for building all the rigs:
1) 3' Aluminum 1" square tube
1) 3' Aluminum 3/4" tube
1) 3’ Steel 1" square perforated tube
10) 1" Square End Caps (furniture tips)
2) 3/4" Round End Caps (furniture tips)
4) 5/16"-18 x 12”All thread
8) 5/16-18 x 2-1/2" hex bolts
4) 5/16"-18 Cap Nuts (acorn nuts)
10) 5/16-18 Lock Nuts
6) 5/16-18 Nuts
24) 5/16" washers (some are used on 1/4 inch rod, but it is fine)
8) 3/4 x .385 x 13/64 Nylon Spacers
2) 8-32 x 1-1/2 machine screws with nuts
4) 8-32 x 3/4" machine screws with nuts
1) 1/4-20 x 12” All thread
3) 1/4-20 Flange Nuts (you could use other nuts, such as 1 cap nut and 2 regular nuts)
1) 1/4-20 x 5/8" thumbscrew (or steal one from the CowboyStudio Shoulder Pad :)
1) 1/4-20 x 2-1/2" thumbscrew or bolt
4) 1/4 x 1-1/2" fender washer
4) 1/4-20 wingnuts
4) 3/16 x 2-1/2 J bolts with nuts
2) Extension Springs 1/4 x 1-916 x .032"
1) 1/2" Two-Hole Strap (for EMT conduit)
4) 1/4" Nylon clamps (5/16 works too)
1) 3-1/2" x 7-3/4" baseplate: 1/4" inch plywood or similar material (Jigsaw) OR 3/16 or 1/4 plexiglass (box cutter + metal ruler, but be careful!)
8) 54mm Skateboard Wheels
8) Skateboard Wheel Bearings
1) CowboyStudio Shoulder Support Pad
1) 3/8 to 1/4 tripod head adapter bushing. (Amazon link, or your camera store)
Step 1: Cage/Fig Rig AKA Mr. Shiny - pg. 1
Mr. Shiny is a very versatile and durable rig. I'd suggest making a cardboard cutout of the size you think you want for your camera before cutting metal. The sizing is completely left to your preference—the size I built is great for a standard sized dSLR (like a 7d).
Parts required:
2) 12" Aluminum 1" square tube
2) 9 3/8" Aluminum 3/4" tube
1) 5 1/2" Aluminum 3/4" tube
2) 5/16"-18 All thread, 12" long
4) 1" Square End Caps (furniture tips)
5) 5/16" washers
1) 2 1/2" 1/4-20 thumbscrew or bolt
2) 1/4-20 wingnuts
Assembly info:
The box channel / square tube will be the top and bottom. The round tube will be the sides, and they will enclose the all thread. The all thread will go through hols in the box channel, and will secure everything together. The top handle is attached with a two-hole strap, that is too small for our pipe, and the camera will mount inside onto a 1/4-20 threaded thumb screw, that will we have "float" with the rig.
First Steps:
1. Measure and cut the tubing.
   a. Cut the square tube or box channel into 12" sections.
   b. Cut the all thread into 12" sections.
   c. Lay out the square tube and all thread. The all thread will go through the square tube, and have a washer and cap nut at the other end. The round tube will enclose the all thread, between the square tubes. Verify the length of the round tubes you will need (9 3/8")
   d. Cut the round tubes
2. Debur or file your cut edges. Cutting metal makes sharp little edges, Make sure you debur or file them.
3. Mark and drill holes.
   A:  You will need 4 holes at the edges of the box channel/square tube for the 5/16" all thread. You will want the holes in about 5/8" or so, so that the 3/4" tube's edges don't extend over the edge. The holes need to go through both sides of the box channel.
   B:  You will need 2 holes that go all the way through for the two hole strap, on one of the box channels. You should center these holes, and verify hole placement with your hole strap. The holes on my rig are 1-3/4" apart. Make sure the holes are on the same sides as the all thread holes. For my design, I used 8-32 machine screws.
  C:  You will need one hole for the camera mount location. the bolt is 1/4-20, and you will need to drill all the way through. Again, make sure the holes are on the same sides as the all threads' holes.
4. Lay it all out.
sensoryhouse says: Sep 27, 2011. 6:31 PM
Nice 'ible.
Here is a slightly suped up version of the roller.  I like to used rollerblade wheels because they are smoother/softer.
vigorotaku in reply to sensoryhouseNov 27, 2012. 6:51 AM
Nice Rigs! All of them -- I like the roller rig!
I set up a Rig with the Atomos Ninja-2 on the Nikon D4.
From my blog:
Once set up all I have to do is start Live View (in video mode) and start the Ninja-2 recording. When I cycle the Live View button on the D4, the Ninja-2 starts recording when Live View is on and stops when I shut it off. Each time the Ninja-2 creates a new file for the next take. I turn on the Focus Peaking to ensure perfect focus and it stays on the whole time (does not reset when Live View is cycled). Perfection!
Check out my rig
here
Dan at Vigorotaku
goldenshuttle in reply to vigorotakuDec 19, 2012. 10:31 AM
great work indeed. having an old skiboard, now it s clear what that will be...weel done Rex.
tylercard in reply to sensoryhouseNov 2, 2011. 8:04 AM
That. Is. SICK.
Nice work, I will be making one of these very soon.
sensoryhouse in reply to tylercardNov 2, 2011. 5:12 PM
They are super cheap if you can get the rails for free and the Meade mount on Craigslist.
MattosaurusRex (author) in reply to sensoryhouseSep 27, 2011. 9:06 PM
Sweet dude! Your Ible says it's not finished yet, but it looks pretty sick as is! Can't wait to see finished version!
crishrx says: Oct 7, 2011. 6:46 AM
Congrats sir......... well done......
MattosaurusRex (author) in reply to crishrxOct 8, 2011. 5:01 AM
Thank you, and you too! That mini camera must have been quite the work of passion, very unique indeed :)
alinke says: Oct 5, 2011. 4:11 PM
nice job! video looks straight out of a tv commerical
colorex says: Sep 19, 2011. 1:15 PM
TIP: When rolling a camera like that, you get noise from the friction. So, get a separate audio recording source.
MattosaurusRex (author) in reply to colorexSep 19, 2011. 2:37 PM
Yup. Actually, if you can shoot separate system sound, or import sound in through an adapter, it's always best; most digital cameras' microphones are lousy for high quality audio recording.
The Zoom H4n is a very popular solution for dSLR shooters. It has XLR inputs, it has 4 built in mics, and it offers 4 track recording. It's a very cool little tool!
colorex in reply to MattosaurusRexSep 19, 2011. 6:30 PM
I thought you should know that : )
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
